That's looking good, I bet it weighs a bit.
No fix...sadly sent amp and sub back to PE today. I honestly did not have the energy to build another cabinet... Plan is to provide a Sunfire HRS12 for now...probably a second one if its not enough.. My client really likes to play the music LOUD...Ouch! Any update on what your "fix" was? What was the budget on the subwoofer build?
Would love to get my hands on a LMS5400. Ive emailed them about how to order one. They dont respondI am surprised you never heard of http://www.diysoundgroup.com/ you could have had few flat packs sent for 2 15" subs and been done. A nice pro audio amp and called it a day. It might be something to look into the future. I have never owned a dayton speaker or subwoofer for that matter. I knew I could not settle for less so I went with a TC Sounds Lms Ultra 5400 in a 7 cube passive radiator box. It was $3000 at the end of it but I am never disappointed ever.
Your client will most likely be disappointed in the HRS12 then. That unit is designed to be small, not loud. Tiny subwoofer <> tremendous output. Physics will not allow that I'm afraid.No fix...sadly sent amp and sub back to PE today. I honestly did not have the energy to build another cabinet... Plan is to provide a Sunfire HRS12 for now...probably a second one if its not enough.. My client really likes to play the music LOUD...
