I tried with another sub with very low fs at the begginng , it was excelent at very low but that was all...
i have allready applied EQ, and at 50hz is one of the fr that i had the biggest peak but there was no punch , instead overwhelming to other fr... the only fr i left alone even the big peak was all the fr below 30hz and without any sensible overwhelming....all these with a sub that had an large peak at 30hz below....
The punchy fr are from 80-120 hz and i can take advantage of all the extra LFE or at least all to the sub if i cut the center-main at 100-120 hz .... (LFE 120HZ)
I believe that is mistake if you make cross at 80hz because all these filtering and the phace changes , destroys all the precious energy at a very crucial fr point!!
Also a sub that would be suitable for all these fr 20-120 , to reproduse at its max all these fr doesnt exist, you must make some compromises if you choose one for all...
My finally thoughts are to add the old sub for the 50hz below , ill see ...
