S
shawn
·Guest
Well here goes, either my sub sucks bigtime, or I'm doing something wrong. I have my sub crossover in windows set to 250hz, as that is as high as the sub itself will go anyhow.
I am using a sennheizer mic through mackie soundboard as my input.
I purchased the fbq2496 today, they didn't have the other model, and only after getting back home, 100 mile round trip drive, did I find that this model only has 1 preset....grrrrr.
Anyhow, here is my graph
http://mydreamhost.net/images/sub-a.jpg
I took multiple measurements and they all looked almost the same, so I'll use that one as a reference.
I have the fbq plugged into a midi usb adaptor on my computer, and the sub is routed through the left channel on it. I held the reset button on the fbq for 10 secs or so but the 'filter lift' button still blinks. Not sure if it's really reset. the digital display says 10.
Are there directions for using the fbq somewhere? only found dirs for the other model, and got confused almost immediately as they seem quite different. Like (no in/out button to press and hold) but if I understood correctly the left meter is always set to input anyhow so I did set my sub vol to the orange,with no red clips, guessing that is correct.
Now what do I do? (Not sure this sub is even worth dealing with after seeing my graph, I placed it up front where the bass sounds 'best' in my seating position)
Can't even get past step #1 as I don't have a 'filter' button on my unit.... guessing there is a link for directions on this model somewhere else on this site.
Or if it's an easy thing to do could someone give me step by step directions on how to fix 1 frequency on my graph, and then i can just keep doing that over n over until I get them all fixed?
