1 - 17 of 17 Posts
so I am looking at some projectors, will be my 1st.... found one on local , Epson 8350 , new bulb ceiling mount and a 100" screen $700, just concerned about some issues I have read about this one. so was also looking at a BENQ 1070, but have seen some bad stuff about this one too...so I'm thinking that unless I get a new one that they all will have some sort of issues, so what is everyone's take on these 2 choices so far ? here is a little info on where it will be at .....the room is almost black walls and ceiling ( light is controlled ) like night in the middle of day!.. ...projector can be from 17 to 13.5 ft from screen ( looking to do 100 to 120 in screen , seating is 1 row and 11.5 ft from screen.
In that dark of a room you will have a great experience. Those are 2 very different projectors though. One is DLP and the Epson is LCD. I am on my 4th projector and have always used DLP projectors.
Try to visit a show room or a friend and see the difference. Either way I sit at that distance from a 100" screen and my family loves it!
Thanks , hope so , after a lot of research was scarde to get the Epson( seen a lot of issues ) and just bought the BENQ ht 1075, will see how I like it . this weekend it will here :sn:
I did not want to sway your decision but I prefer the DLP, I have the Optoma now and love it. Watch the throw distance with the BenQ, other than that I might have gone with that projector. Use www.projectorcentral.com if you have not been there.
Discussion Starter #5
im pretty flexible on where its mounting ( ceiling mount ) and room with black walls and roof . overall a really dark room , hope it don't disappoint coming form a 55 LCD tv
The BenQ w1070 is a nice projector...the only downside (IMO) is the lack of a lens shift that is for a wide range for mounting the projector. You just need to plan out your mounting for your size screen, and get it very close to what is needed. Other projector allow 1/2 the screen or more for lens shift to move the screen vs a few inches on the BenQ W1070.
Discussion Starter #7
Ohh... I got the HT1075, so its suppose to have lens shift , so UPS just dropped it off , cant wait to get it home to see how it looks,
The benq 1070 is a great all around projector for entry level in my opinion.. I watch TV and movies in light and dark rooms and have 1 in my living in bedroom since it was released.. I'm now trying to figure out what the next projector for me should be looking in the 1500-3000 range.. let me know your thoughts people.. I would like a brighter picture in dark and lit rooms without loosing anything I have today in the 1070..any suggestions would be appropriated.
Discussion Starter #9
well now I've had my 1075 up and going for a month now, I'm happy with it and every now and then I can notice the rainbow effects everyone was talking about, my room is extremely dark ( even during the day ) so brightness is not an issue at all, I have noticed when the shot will pan from one side to the other , seems to skip( sorta) or maybe something to do with refresh rate / or frame rates, I'm not sure, but that's about all that I can pick apart with it now, so guess time will tell....as of now I'm happy with 120" viewing pleasure
Been using a BenQ W700 for 3 years. I plan on bumping up to the 1070 or 75 after the current phase of upgrades is finished.
I've been very happy with the W700. Yeah, it's only 720p, but when I got it I didn't have any HD content except through my PC. I don't know if anyone else has this problem, but Excel 2013 is very disorienting on a 96" screen...
Discussion Starter #13
Ok ....so this has happened 4 or 5 times, projector shuts off from over heating....it is ceiling mounted about 22" down , should have plenty of clean air ( measured temps with laser temp gun to about 77F near by it ) what can be the reason for this( it mostly has been after it has been on for a few hrs or so
Discussion Starter #14
well I set the settings to ( high altitude) fans are much louder, but guess that solved it - but is still a bit loud 54 - 56 DBZ, and im sitting right under the projector 6ft away...but im really near sea level, anyone have any ideas?
You shouldn't have to switch it to High Altitude... Have you tried calling the Manufacturer...it might be defective.
Is it beyond your return date? If not i would return it and ask for a replacement...if you are lucky they might ship one out so you can swap it out after the new one arrives.
Discussion Starter #16
is is still under warranty and I got a 3 yr extended on it also....and I have not called them , but will give it a shot
1 - 17 of 17 Posts
