1 - 4 of 4 Posts
Best rescaling the graph to get a more representative view and make it easier to judge good/bad, for that measurement try setting the bottom of the graph to 60 dB and the top to 120 dB - use the Limits button at the top right of the graph to change the settings.
Super Moderator
After some fun getting started with my laptop and REW my UMIK arrived today. Here's how it compared to my GarageBand mic - what do you think?
Would be nice to know which trace belongs to which mic...? :T
Also I have a bulge @ 50hz and a nasty suck-out/ interference at 128hz - any ideas?
Sure - ignore that trace and go with the other one. :D
But seriously, parametric EQ is the way to go to address subwoofer frequency response issues.
John, is this a better graph. The speakers do not sound good (more on the right) when i generate a sine wave 128hz - I'll measure each each speaker to try to isolate. I moved the speaker forward 30cm to try to lessen/ offset the port tuning frequency? (see here)
Wayne, it's a pop quiz :scratch answer will follow the first guess :TT
Thank you
G.
1 - 4 of 4 Posts
