1 - 9 of 9 Posts
I am looking for suggestions on a decent amp board, 2 full range speakers, and a subwoofer to put into a single box to use as a Bluetooth speaker. I would like to stay under $200 for these components. I am looking along the lines of a 5-6 inch woofer, either ported, or possibly a passive radiator. I would also like at least 100w total power. So far I am leaning towards Tang Band for full range and woofers.
id say that would be tight depending on how loud an clean you want it to sound , an does 200$ cover the box or do you already have the wood for one
let me know iv got some suggestions for you an if you want i could do a cad moch up a blueprint for you
an id say for a really good 2.1 bluetooth boombox up you budget to 300$
My thought is that if I can buy a kit from Parts Express for $120 with a box, then I should be able to build one from scratch by spending $200 on just the speakers and amp. Total will probably be around $300. I have WinISD and access to CAD software and an entire woodworking shop, so I should be good there. Here is what I am looking at:
id of said go with this for a little extra an get a lot more spl an bang
TAS5630
Rockford Fosgate P1S4-10 - Punch P1 10" Subwoofer 4 ohm
an four FaitalPRO 4FE35 4" Professional Full-Range Woofer 16 Ohm (two for the left channel an two for the right channel each wired in parallel)
al that comes to 280$ before shipping an tax
that TPS3116D2 iv had before an like this parts review
Only good for a 2.1 if you dont mind having zero mids
Bass is good. Highs are good. There is no Mid range. Switch does nothing. Chinese design. Better off purchasing the Dayton Audio Bluetooth DSP series, Sold out as of now but much better engineered.Do not buy if you want a 2.0 system. The stereo satellites will give no low end even if you designed them to. If you want
__
now i would go for the dayton either
this is my dream build you might go for
ther are 4 fullrange 8in drivers two for the left an two for the right
each pair wired in parallel to 4ohms each to get 75watts an each connected to a 4ohm High Pass Filter Frequency: 500 Hz
an ther are two 10in woofers 1 left 1 right both are 8ohms an are wired in parallel to
4ohms for the .1 postion to get 150watts the pair connected to one Low Pass Filter
Frequency: 500 Hz Impedance: 4 ohms
all run off a TAS5630 Bluetooth 5.0 300W (150W+75W×2) High Power Class D Digital Amplifier; 2.1 Channel Subwoofer Hi-Fi Audio Amp (with Power Supply)
links
the cabinet outerdims are 56.5in by 11in by 9in
the inner dims are 54.5in by 9.25in by 6in
all 4 8in fullrange in a open baffle config the 10in woofers are in the sealed compartment
heres my cad files an pic conceps
174424
174425
174426
174427
Discussion Starter #6
That looks awesome! I am looking to build something that is small enough to easily move around, but large enough to get some good sound out of it. I am a little unsure of the amp though and might end up going with the PE amp instead.
hey heres a updated suggestion
174458
174459
174460
174461
174462
174463
Discussion Starter #9
1 - 9 of 9 Posts
