1 - 14 of 14 Posts
Hi!, i'm from Colombia and i'm about to buy the SA240-B plate amplifier in amazon or parts express, the question that i have is:
i have the subwoofer box and the subwoofer (12" 500w, no rms), ok, but also i have two small (but powerfull) satellital speakers for mid-high sounds, i don't have any more amplifier. can my satllites work whit the SA240-B high output without any other amplifier?? like a 2.1 sound system??
thanks in advance!!!
pd: if you know any other plate amplifier, for that price range (if it's cheaper, better), that works for my setup. :ponder:
amplifier link:
amazon. com/Dayton-SA240-B-Subwoofer-Amplifier-Boost/dp/B000K2YZZ4/
Hey, you're going to need a receiver to provide full range amplication, which goes into the high level inputs on the amp, then send the >50-100hz signal to those satellites for your mid/highs while the plate amp drives the sub <50-100hz.
Welcome Amin. Have fun. Dennis
Hello,
Welcome Amin. Congratulations on your new acquisitions. May they bring you many hours of sonic bliss.
Cheers,
JJ
The setup you describe will not work.
Parts Express sells a Dayton 2.1 plate amp for cheap but it doesn't output much power. I think 25W left and right with 50W to the sub. I'm thinking about using this in a small bedroom setup.
Discussion Starter · #6 · (Edited)
hey, there has passed some time, but well, thanks for your replies, but i'm a bass shake lover, and i buyed the Dayton sa240-b 2 weeks ago and it arrived today :dumbcrazy:, ohh man i'm so happy that i can't describe how much. ok, this is some pics of the amplifier and my setup, there is no subwoofer o sub box becuase i'm fixing it, making the amplifier enclosure and sealing it, the i'll post more pics soon!! with the box dimensions and the subwoofer characteristics.
the Dayton sa240-b in plain
the satellital speakers that i mentioned before (15 RMS)
speaker cables
power cable, lol!!!
Auto on(on signal) and phase feature(rev or normal)
32 bands pioneer equalizer(16+16) sg-60
my pc(320, ocz gold 2GB ddr2 800, phenom x4 9550, gigabite ga-ma78g-ds3h, damaged 8800gt)
my command center
22" samsung syncmaster 2253lw
What kind of sound card do you have in your PC, or are you running on-board. On board is ok, if it has a digital/optical interface. Even so, a good sound card will make all the difference in the world. If you route it to a reciever then to your speakers, you might not even need, or want to use that equalizer any more. When I installed my sound card, it came with its own equalizer, and a mic to set up the speakers. After tweaking it out , wow, what a difference. 192khz at 24bit.
I use onboard sound card(realtek), i have the digital equalizer set to disiable, 'cause i like more the analog equalizers than the digital.
I am not as familiar with the differences between the analog and digital. Is it a sound preference, or is it a personal preference.
Thats cool. Just curious. I am pretty sure some sound cards offer a MIDI port that supports analog EQs. I will look into it. I am not sure if they offer 192k, just 96k, but for 2.1 that might be all you need. For me, I like to be able to fine tune each frequency. It takes a while to get it right, and you can save different profiles, like I have one for movies, one for live concerts, MP3, gaming.
What you have so far is nice, and I am looking forward to see how you progress.
Discussion Starter · #14 ·
hey thanks for the replies, what you are saying is true, i have a sound blaster audigy z (broken) and it has the midi port, but i never tried to connect it into an equlizer, in the moment i had it working, i didn't know wich was it function (like 4 years ago).
I'm reaparing the spaker (not me, in a speaker shop), changing the voice coil from 8ohm to 4ohm and the cone for a new one, but i can't post more pics until friday or saturday because i'm delayed with some stuff in college.
1 - 14 of 14 Posts
