1 - 12 of 12 Posts
I'm having problems with my REW Sub measurements, im able to take 2 correct measurements then the third is a straight line , it's driving me crazy ?
Have'nt used Rew in a little while, but i used to work fine ??
Using a EMC 8000 mic with ART usb dual pre.
No idea why , but ;
In cases like this ( inexplicable REW behavior ), JohnM has recommended clearing REW's stored preferences & then re-opening the program ( usually with good results ).
:sn:
Discussion Starter #9
Well it did'nt work , after 2-3 measurements ,i'll take another and get a flat line. ??
Thanks anyways for trying to help !!
That's too bad .
Have you made any changes to your measurement system ( such as a new OS being installed ? / a new computer maybe ? )
:sn:
Discussion Starter #11
No i have' nt ,... funny thing is when i unplug Art Dual Pre from computer , i can take many measurements ( sweep coming from labtop speakers) ??
Sounds like a communication problem between the Preamp and computer(USB). Try a different cable, different USB port, reload drivers, make sure software is latest release.
1 - 12 of 12 Posts
