1 - 7 of 7 Posts
Anyone know of a good 2-way kit or design using the Dayton Reference RS180 woofer? just 1 woofer is fine, I think MTM would be a little over budget. I am capable of building the crossover with detailed instruction but would also like to take a look at a kit including the Xover and tweeter if possible.
Thanks!
No, because the design is relying on the second driver for output to balance the frequency response. Also, having the MTM like that limits the vertical dispersion so less sound bounces off the floor and ceiling (comb filtering effects).
If you wanted to rework the crossover completely, it *might* work. But chances are, you would have to pad down the tweeter.
Also, there are subtle differences between the 4 Ohm and 8 Ohm driver that go beyond just impedance. The frequency response and resonance / breakup points are altered a bit too.
That's a popular kit at PE. Other than being tall for the second driver, it's pretty simple to build -- not a bad first project.
Good luck.
Check out the Hiddenite kit from Selah Audio.
I built these speakers and they sound quite good for the money. A nice detailed sound with a surprisingly good tweeter.
The kit inlcudes everything but the cabinet and it's a great way to get started with putting together your own system.
1 - 7 of 7 Posts
