1 - 5 of 5 Posts
I'm not sure weather they make an audio recepticle for a locking plug or not i have never seen one advertised. In my eyes as long as you have good quality ends on each there is no need to spend the extra:spend: on the expensive connectors but if you get curious or really must do it then check out PS audio or Music direct. Good luck on your search and please post your findings.:T
Check out PS Audio, I believe they have what you are looking for.
1 - 5 of 5 Posts
