1 - 5 of 5 Posts
Setup: 2011 i5 Mac mini attached to a Yamaha RX-A700 outputting to a Sharp LE632U
I initially thought this was the "Best resolution for display" setting misinterpreting the res when turning off my AV equipment. In System Preferences, I disabled this and have set it for 1080p, then 1080i. Every time I turn off the AV equipment for a few hours and come back, when I turn it on, it's stuck on that blue screen that flashes when you connect an external display on any Mac. The TV also indicates that it's at 1 resolution lower than what I happened to set it to before I turned it off.
That is to say:
1080p becomes 1080i
1080i becomes 720p
Background processes still work, I can still SSH in. Screen Sharing or vnc DO NOT work, which I find odd.
Anyway, hoping someone else out there has seen something like this. All worked well in Lion.
Additional Details:
  • No power-saving features are enabled (sleep, etc)
  • No screen-savers are enabled
Nope. Still happens.
All sleeping and power management is turned off.
Nothing peculiar in /var/logs/system.log other than 'new display detected/detached' when AV power is cycled.
I'd have bought an HDMI Detective by now if it always did this, but I didn't need it before Mountain Lion, so there must be something else I can do.
I'm almost to the point of using a STB as a client for Plex as my main device and just leaving the Mac mini headless. Or buying an hdmi detective.
No help for your either. I had external monitor issues after upgrading from Snow Leopard to Lion, after a few updates it finally started working reasonably well. Have not made the change to Mountain Lion, don't want all the hassle again.
I don't use my Mini for HTPC, and haven't upgraded to 10.8 yet, but would advise:
1) When it is hanged, SSH in and have a look at system.log. e.g.
Code:
tail /var/log/system.log
2) Use a HDMI buffer and decoder (like the HDfury) to force a stable HDMI device to be on the Mac's output.
1 - 5 of 5 Posts
