OK, Kevin has talked me into (read upsell (also read - he didn't have to push too hard) buying a 21" Maelstrom-X and building a sealed box over going with a ported 18". My current setup is a Wicked One folded horn with a pair of JL Audio 10" drivers...which sounds great, but it drops like a rock below 30hz. The 21" Mael should easily replace the folded horn, especially when pushed with the EP2500.
My current box, being a dual folded horn, is basically a coffee table format (but placed in the room like an end table next to a couch and wall). It's sized at 36" X 36" X 14" It looks like this:
The 21" is going to be in a similar format, simply because I like that shape, and it works well in my livingroom/theater. Kevin suggested 10-12 cf sealed, believe it or not! So my box is going to be looking like 36" X 36" X 20" which should give me about 12 cf after bracing and sub displacement. (correct me if that sounds wrong). I could go bigger, but the man himself said no need. (an old photo, quickly chopped in MS Paint)
I haven't learned Google SketchUp yet, and I typically do 90% of my designing in my head. Maybe, if I have time, I'll see if I can figure this out and do a digital drawing...
I have a decent, basic shop in the garage, and I'm a capable (though out of practice) woodworker and I enjoy fun projects.
So, for my Mael-X 21" build, I'd love to do something lighter then my MDF monster of a folded horn. That thing is a beast to move around. I was sore for days after tumbling it around the living room to measure and listen for the best sub location...So I'm hoping to make the 21" box a bit lighter. I'd also love to do something fun like install an Acrylic side panel on the sealed box, with a small cold cathode tube inside to show off the bracing I plan on building....but I don't think my budget would allow for a $100 piece of plastic, just to show off my fancy wood working.
That said, I'm thinking I might have to mix MDF and plywood to lighten the box and keep costs down at the same time. I'm thinking doubled up 3/4" plywood for whatever face I put the driver on (I'm still debating narrow face or wide face), MDF on all other panels, and 1/2" plywood bracing throughout.
Does anyone see any issues with mixing MDF and Baltic Birch Plywood?
What about using 1/2" bracing throughout? Since bracing is used to break larger (lower resonating) panels into smaller (higher resonating) panels, I don't see the need for 3/4" bracing. I think a better design should take the place of MOAR WOOD!
I'm also planning on making the bracing interlock into the side panels. Just cutting some dato slots that the bracing would fit into. A little glue, and it's be solid like a puzzle piece.
Again, this is all just thinking out loud. Feel free to chime in, or ignore completely. Chances are I'll do whatever floats my boat...but I'm always open to ideas and thoughts that would help me avoid mistakes.
