26" Cube, Maelstrom-X dual PR build
4811 Views 22 Replies 6 Participants Last post by  altahometheatre
I figure I would make a thread with my build. I made a variation on SturmMDs build and made it 26" so that I could center the PRs in the cabinet. I am using a Crown XS1200 to power this, 3kw at 4ohm mono. I have a Gen II Maelstrom-X, I had a Gen I, but it was defective and Kevin replaced it, so Kudos to him for awesome customer service. After bracing and drivers the internal should be about 7.5 cubic feet and modelling in winisd gives a tune around 17hz. I am using 14 washers on the PRs and have about 1750g total weight on them. I have tried the sub with various levels of fill and will get into that later. Using an SMS-1 with a 17hz subsonic filter to EQ and a Pioneer SC05 crossed over at 100hz. Feel free to ask any questions.
At the time I didn't have any tools (just bought a used table saw for $60 last week) so I had a cabinet maker friend help me build the enclosure. This is my first DIY anything.
We rounded over the outer baffle with a 1/2" roundover bit and a 1.25" on the outside of the box if my memory recalls.
The most work was probably the prepping for painting really. Betwen filling imperfections with wood putty, sanding, wiping down the entire enclosure, do a coat of primer, then do the same thing a time or two before we just sanded/wiped down and painted. It was a lot of work.
Then we started the black paint, we did 2 coats of black and then 1 coat of high gloss. Some of the pics are kinda dusty/fuzzy...sorry about that.
I did a lot of sanding, perhaps a bit more than I needed to, but I wanted a good looking enclosure.
Here is the finished product in my room:
I also bought a custom made subdude HD in a 26" cube configuration, I can take pics if you want and put them up.
At the moment I've been playing around with fill and things of that nature.
This is the uneq'ed mael with fill in my room
Here is a pic of the mael with 6-7 pounds of fill eq'ed
About half that
And then no fill
After a suggestion by Ricci, turned off all of the EQ and did a measurement from about 2" away from the center of the mael just to see what it would look like and this is it
After I did that I rememebered that my Ascend Sierra's put out the test tone sweep as well so I disconnected them and this is a nearfield measurement with nothing but the Maelstrom.
It sounds great, but the graphs show something kind of weird, I assumed that a sub should be relatively flat to it's tuning, but I get a big hump in the mix with no EQ, any thoughts?
21 - 23 of 23 Posts
Absolutely, so far the mael doesn't even seem to break a sweat. It can take a lot of power.
You do have to be careful. Any driver can fail given the right circumstances. Sustained high power content near the tuning frequency of the PRs is one of the biggest dangers because the power dissipated across the coil is huge if you are pumping a couple KW into it and the driver's ability to dissipate that heat is greatly diminished when the driver isn't pumping.
Kevin Haskins
Exodus Audio
I did decide go with the speakon connections. I honestly was boggled for a couple of weeks over how to wire it, for some reason it just seemed greek to me. I got the 4 pole connector. Basically if you are going to wire the sub bridged to an amp, go with 4 pole and if you are just using a single channel use 2 pole. My speakon has 2 + and 2 - for wiring with screws to clamp down the speaker cable. I have my maelstrom wired in series so I have one of the positives on the mael to one of the positives on the speakon and then I have that negative and the other positive wired to each other with the final negative wired to the other positive on the speakon. It sounds kind of weird I guess.
Here is a link...maybe it will explain it a bit better. I'm using a crown amp btw.
http://www.crownaudio.com/pdf/amps/126986.pdf
Thanks for the link,
The wiring still feels greek to me. Maybe when I get the speakons it will make more sense to me. I will likely make a drawing of the wiring plan before I hook it up to ensure I am not going to blow anything up. I dont even have my head around 2 Ohm / 4 Ohm / bridged etc concepts.
Darryl
21 - 23 of 23 Posts
