21 - 40 of 44 Posts
Discussion Starter · #25 ·
Sweet. And just 1 long port would do the trick?
24x38x22
.75in material thickness
800 in ^3 bracing
290 in ^3 port volume (5" diameter x 14.78" length)
.25 driver volume
1
driver
net cubic feet = 8.862
Those dimensions seem okay?
Discussion Starter · #29 ·
SWEEEET! Im working up a sketch now will post when im done.
Looks like I will have the port coming through the very top of the cabinet. The driver will be front firing, towards the bottom of the cabinet, and the plate amp on the rear side.
That all sound okay?
I would try to have the port down firing but then you would have to add some sort of legs to give the port clearance. I also read somewhere that a down firing port can also minimize port related noises.
Mike makes good point about watching that nothing get dropped down the port if you place it on top. If you are going to have it on top I would really recommend some sort of grill to protect from anything falling in.
Discussion Starter · #34 ·
OOOK. Here is my finished blue print. Let me know what you experts think! I the baffling in the middle I had to cut in half or else it would come in contact with the pvc pipe. Suggestions are welcome, and needed!
Thanks!
edit: Grr, came up small let me fix it...
Discussion Starter · #38 ·
Woo Hoo! Going to start working it on it shortly. My VERY last questions (I promise!):
1) How much fiberbglass insulation do you recommend?
2) What kind of glue do you recommend?
3) Is it okay to screw things together? (I never really noticed many screws on people's subs)
THANKS SO MUCH!!!
1. A couple inches thick glued to the walls of the enclosure. Another option would be egg crate foam sold as a mattress pad at WalMart for $15-$20. Much easier to work with.
2. I've always used a glue gun with hot glue to glue egg crate foam. Others have used 3M spray on adhesive. Make sure you reads the label on proper use, you have to spray both the cabinet wall and the insulation.
3. Wood glue and screws can be used. For screws use 15 inch long coarse thread drywall screws. You have to drill a pilot hole and countersink first so the MDF doesn't split. Do some test holes on a couple pieces of scrap MDF first until you get it right. The pilot hole needs to be a hair smaller then the shank of the screw.
21 - 40 of 44 Posts
