21 - 29 of 29 Posts
They'll have to take my backward compatible, SACD playing, 4 USB & media slot touting, touch sensitive button FAT from my stiff dead hands. :paddle: LOL
I'm with you on this, I really dont want a slim, I only want bitstreaming :explode: :hissyfit: :wits-end:
Too funny! 3 days after posting this I get the YLOD! Thankfully there are some really good instructionals on You Tube on how to re-flow the cpu and gpu. All's well again.:sweat:
Ares did you notify Sony so they could download a virus onto my PS3? Or maybe they are monitoring the forums.
Discussion Starter #23
I secretly work for Sony and I check out forums to see who has the Fat system.:D All joking a side are you sure that one or both chips have lost contact with the motherboard?
Discussion Starter #25
I will assume that you have changed the stock thermal paste and are using some better quality thermal paste, which will go along way to help prevent this from happening again.
Discussion Starter #27
Sounds like AS5 it's good stuff it's what I use as well, the one thing I don't like is the 200 hours of break-in, I also like the AS Céramique it's white and has a break-in of 25 hours. I am glad to hear that this worked out for you.
Discussion Starter #29
The break-in process happens when the paste goes through heating and cooling cycles,according to Arctic Silver their thermal paste goes through a phase change, in which during the break-in process the thermal paste thins out and then starts to thicken a bit. This whole process stops after break-in this is all according to Arctic Silver.
21 - 29 of 29 Posts
