Status
Not open for further replies.
1 - 1 of 1 Posts
I have 4 Infinity 1260's. They are USED and in working condition, and I DO NOT have the original boxes for them, but should still be able to package them appropriately.
These do wonderful in small 1.5 - 2 cubic foot sealed boxes and many people are using them nearfield in place of transducers.
I'm looking for 60 a driver + actual shipping. I'm open to offers, but send those via PM's.
I'm in the Indianapolis area, but will be up in Chicago at some point in the next few weeks, and down towards the Louisville KY area if that helps any.
I will get pictures up shortly.
The number-one aftermarket car audio speaker . . . five years running* When you want a truly moving car audio experience, look no further than Infinity® Reference speakers. And you won’t be alone in having great sound in your vehicle. Infinity Reference has been the top-selling aftermarket car audio speaker for five years running, and with good reason. Infinity Reference continues to lead the industry with innovative materials and breakthrough engineering that delivers extreme output with accuracy and detail for the ultimate listening experience on the road. And proprietary features such as patent-pending Plus One® cones, true four-ohm topology, and UniPivot™ edge-driven tweeters leave the competition scrambling to keep up. So experience what so many others have enjoyed for years, and install Infinity Reference speakers in your vehicle. Prepare to be moved.
General Specifications
Impedance: 4 Ohms
Audio Specifications
Sensitivity:93dB
Frequency Response:23Hz – 400Hz
Dimensions
Diameter (in): 12-3/8"
Mounting Depth (in): 6-7/16"
Features
Polypropylene woofer cone
When you want to experience seriously low bass that is reproduced with detail and clarity, you need a woofer using a cone that is stiff yet lightweight. The Reference 1260W delivers an exceptional bass experience by using a woofer cone made of polypropylene. Polypropylene is the perfect combination of strength and light weight for high power handling and efficiency. It can deliver the deep bass notes that rattle your ride as well as the subtle bass notes of an audiophile-quality listening experience.
Large-roll rubber surrounds
To ensure high-performance, distortion-free bass for all kinds of music, a subwoofer cone needs to be strong when moving the large amounts of air that we hear as bass. One of the places where a subwoofer cone can be at its weakest and can distort is where the cone attaches to the basket. To ensure that the cone does not bend or flex at this connection, a strong material must attach the basket to the cone. This attachment is called the surround. Where other companies’ products use inferior materials, the Reference 1260W uses large-roll rubber surrounds. The roll’s size and strength provide stronger cone-edge suspension and absorb any distortion that might travel up the cone’s edge. The result: exceptional sound quality and detail. And if better sound quality alone isn’t enough, rubber is much more durable than other materials commonly used in surrounds. It will provide many, many miles of rocking out to your favorite artist.
Progressive spiders
No, this isn’t the bug but the name of the corrugated woven material just under the speaker cone. This important part of a subwoofer is designed to keep the subwoofer’s voice coil moving as linearly as possible. In other words, a well-engineered spider is key to keeping control over the entire woofer cone. To ensure optimum control,the Reference 1260W uses a a progressive spider design that exerts more force as the voice coil reaches its limit. With a Reference subwoofer, you will hear nothing but deep, tight, distortion-free bass even under the most extreme performance conditions. As we said . . . go ahead and turn it up!
Large, two-inch (51-millimeter) voice coils
When it comes to bass in the car, you want to turn the power up. However, too much power, converted into heat, destroys speakers. The Reference 1260W voice coils two inches (51 millimeters) in diameter, which provide plenty of heat-dissipating surface area with high output and long durability. In fact, the 1260W can handle up to 1200 watts of peak power, far more than competitive subwoofers at the same price. So go ahead and turn it up. We want you to.
Sealed boxes
Don’t have a lot of room? Looking to hear every subtle detail in your bass? Add a powerful subwoofer amplifier to a sealed box loaded with a Reference 1260W subwoofer. You just might hear all the sounds that you want to hear.
Vented boxes
Have a little more space to work with? Want people to hear you coming? A vented box might be for you. Vented boxes maximize bass in the 40Hz to 60Hz range and make more efficient use of amplifier power for a huge bass experience.
1 - 1 of 1 Posts
Status
