Hi
I'm building a new home. I have a room that will be 4.45metres (14.6 feet) long by 3.74 metres (12.27 feet) wide by 2.54metres ( 8.3feet) high. I have been to a few stores selling HT components (AV receivers etc), with one store (that had branding on it windows stating BOSE, ONKYO etc) who basically told me I only need a 5.1 unit. In fact the only thing he would sell me was a bose system. To which his way of demonstrating this unit was to drag to a theatre room and turning up the bose system so loud that you couldnt hear each other talk.
At a price of $3500 I can do so much better else where. but the one thing that stuck in my mind was that he told me based on the size of the room that a 5.1 would be more than enough and to go for anything more wold mean i would loose definition of the sound being produce. Mainly due to the speed of the sound relative to distance from the seating and the location of the speakers.
Now I have an understanding of the speed of sound and the delays that can be imposed through the recording (movie sound effects etc), and a basic understanding of the layouts of speakers for the various types of units (5.1, 6.1, 7.1 etc). But is there any rule of thumb thats says that you are better off with a 5.1 for this size room or 6.1 or 7.1 for that size of room. Or can use virtually use any system in my size room?
Being that I am from Australia, our prices out here are considerable different to what you have in the US. But even so I am not too concerned about price at this stage. I mainly want to make sure that i have sufficient cable in the walls and ceiling. I'm fairly sure i will be using a projector probably one of the panasonic 1080p units. Other than that I am not concerned about the brand of the AV unit at this stage except to say the bigger name Onkyo, Marantz, denon etc will be in the running. It will come down to bang for my buck and the number of input and outputs.
I also know that at this stage most blurays and dvd are only 5.1, but i know this will change in the future, but is there a golden rule about size of room to number of channels.
Jeff
Jeff
