I recently setup a 5.1 Focal system with the rear surround speakers connected using this cable
24/0.20mm Figure 8 with trace, my front and centre channels are cabled using 2 x 79/0.2mm, which is exactly 1/2 the wire content of the Jumbo cable but still 3 times thicker than the heavy duty cable.
The issue I have is, when I’am using Audyssey Speaker configuration for Onkyo TX NR609, the test tones out of the rear surround speaker is much lower then from the front and the centre.
I’am still in the configuration phase and wanted to know whether the length of the cable was the issue since the rear speakers are drawn for about 15 mts before they connect to the receiver.
Question 1: Are the test tones softer on the surround side speakers?
Question 2: Would the length be causing any signal loss?
Question 3: Will using the type of cable which is in the front and centre channel improve the gain significantly?
Other Related Questions:
Question 4: During the Audyssey Setup the first page asks me to either select front high or surround back, not sure what I should be selecting as I have a 5.1 setup and the surrounds are on the side.
Question 5: With the audio back from the TV on the HDMI out from the receiver, how do I know whether my TV is compatible with the service?
I have a 4 year old Samsung FULL HD 50 inch Plasma
I would appreciate if you people could help answer some of my queries if not all.
