1 - 2 of 2 Posts
I finally repaired my hyper-board on my 50h82 using advice from these forums and the picture is great,
now i have another problem with the set. The onboard sound is unable to generate much volume, and seems mushy. I am reminded of car speakers which have been "rock and rolled" to death. this set was connected to a surround sound system when it was my primary tv, then when the hyper-board failed it was replaced. Now that it is again working I was going to put it up for the kids. It works fine and sounds ok if connected to a sound system, however i hoped to use it as a stand alone tv. Iwent ahead and tried to replace them with another set of 8ohm 15w speakers, but this had no effect on volume or sound quality.
Any advice, or guidence reguarding this issue would be appreciated
thank you
I am not familiar with the particular TV but one idea would be to use an inexpensive set of powered computer speakers. You can get a set for under $20. If there is any audio out or headphone jack you can use that.
Good luck
1 - 2 of 2 Posts
