1 - 2 of 2 Posts
Hi! I have a 62" Mitsubishi model # WD-62530. My TV has me quite confused. I don't really know anything about fixing it but hope you may be able to help. If I try to turn the set on it makes a funny noise then shuts down. I replaced the lamp & reset the TV. I read another post that says to push the buttons on the front & see what the LED lights do. When I do that it flashes 6 times, then pause, then flashes 6 times, pause. Any ideas?
Plain ole user
Your post was moved to the Mitsubishi Forum in service and support to maintain forum organization and to make information easier for others to find.
You code would be 6-6 which simply means that the lamp did not light. I would check to make sure you did not push the connector out of its socket and that the lamp is seated properly.
1 - 2 of 2 Posts
