My Uncle and I have started working on my box. It will be around 7.6-7.8 cu.ft after bracing and everything is accounted for. There aren't many pictures becuase it is only about half way done. I will hopefully be getting more before it is done, and with the driver installed and in my room.
The box dimmensions are 48" tall and 20" deep and wide. We will have two window pane style braces. One near the top of the port about 2 inches away, and one about 5 inches above the driver. We will be runing a strip of thin wood between these two braces to help keep those braces "braced." lol.
The port is 18.50 inches wide, 2 inches tall, and 55 inches long. The length is divded into two parts, one 34 inches long, and another is 17 inches. There is a 45 degee piece of MDF that will go between these two pieces of wood which will keep the port at two inches from the back wall; I don't remember how long that one was though. There is also another 45 degree piece of MDF that is on the bottom of the port so that it will have better air flow. That also was cut the right length to keep the two inch spacing correct.
Drawing everything out first:
The cut outs ready for nailing and gluing:
The 45 degree angle for 17 inch part of the port:
Don't remember what this one was for, just looks like another cut out picture:
IMG]http://i536.photobucket.com/albums/ff323/airsoftsniperm4/UTGM324Gen3forSale034-1.jpg[/IMG]
Assemblig the slot port:
Roundover on the top of the port:
Port exit. The lighter piece of wood is for a better screwing place for the front pannel, as it will be just screwed on so it will be easier to maintain if needed. I will make sure that the holes will be pre-drilled so the wood won't split, although I am pretty sure my Uncle already knows this becuase he is a very experienced wood worker.
The port exit will have a roundover to help with chuffing and port noise.
A quick look at a Ford Ranger Pre-Runner by my house. They have around $150,000 tied up in that easily.
There is one neat thing that we might be doing for this box. Since the Mal-X wieghs in around 50 pounds we will be taking 1/2 inch steel and making a mounting ring that will go on the inside of the box, right where the mounting screws will be, so the screws have extra strength to support that weight. Hopefully, we will have it done, but my Uncle is really busy and might not be able to get that finished. We might be spraying on a bed liner to protect the box, but I will have to see how much it is first. Otherwise, I will just go with Flat Black. It will have a small roundover on all outside edges of the box to keep it from splintering if it hits a wall, of something, and it just looks better to boot.
Any questions or comments are welcome.
That's about it for now. More to come later. :bigsmile:
