1 - 5 of 5 Posts
I'm trying to program my MX-980 remote. I tried AV8003 as a substitute for the AV7005. Is there a better choice. I can alway program each key but I have better things to do unless necessary.
I know the serial commands from the 8003 wouldn't work at all as there was a major change in the format.
vol/on/off and several others do.
Are you using RS-232 to expand the programming ability?
I need feedback and guaranteed control so I am converting the AV8003 module to work with the Av7005.
1 - 5 of 5 Posts
