Status
Not open for further replies.
1 - 2 of 2 Posts
These arent that pretty but they are good solid sound panels. I forget the material but they are rated a little better than Owens corning 705.
These are 8 Panels made of 2x1.5 inch thick panels glued together.
Each panel has carpeting on one side so when glued together both sides are carpeted.
I then painted the yellow sides that showed so that it looked black unless you look right at the edges where you can find some spots I missed.
They aren't super pretty but they are cheap.
Will sell 4 for $50 or all 8 for $80
For that price you can put 2 together in your own frame and have 6" think bass trap for $20 each!!!
1 - 2 of 2 Posts
Status
