1 - 12 of 12 Posts
miniDSP will introduce at CEDIA (September 10-13) the miniDSP Home Theater Series of 8-channel HDMI audio processors for home theater tuning:
http://www.minidsp.com/ht-series/nanoavr-dl
This is the PRELIMINARY manual:
http://www.minidsp.com/images/documents/nanoAVR DL User Manual.pdf
Many had asked for a unit like that...
:) Flavio
Cool:clap:! I'd like to see one that will do HDMI in and 8 RCA analog out. You could go in to a minidsp via hdmi and out to separate power amps via RCA. Oh and I'd like to keep the sampling rate high or have the unit do automatic sample rate matching of the incoming source. That would be a no-brainer with HTPC folk!
well, there has to be a difference versus a more costly solution (i.e. a HTPC with the standalone 7.1 Dirac Live version)... that difference is 48 KHz operation and fixed DSP gain, at the announced 549 US dollars for both DSP processor and Dirac Live license (plus freight and taxes) I'm confident people will find it a no-brainer.
Ciao, Flavio
Is the price of the stand alone Dirac Live PC software going drop in light of this cheaper hardware + Dirac Live?
Also will any USB mic work with Dirac Live as long as you have calibration files? I already have a Dayton UMM-6 from Cross Spectrum Labs with several calibration files.
Hello everybody,
i'm reading here since some time and this is my first post. I'm german, so please excuse the flaws in my writing. ;)
I own Dirac Live already and have it running on my htpc. Could i use my Dirac PC License to activate dirac live for miniDSP?
It would also be nice, if i could use my calibrated ECM8000 with my Behringer interface for the measurements.
I really look forward for a device like this, because i'm not too satisfied with the usability of my htpc and would rather go back to a standalone bluray player without losing the great benefits of Dirac. It would also be great to have dirac correction for my PS3! :)
Cheers,
Belgarion
Discussion Starter #7
hello Belgarion,
you would not be able to use your ECM 8000 with Behringer interface with the miniDSP unit, your current standalone Dirac Live allows for that but a miniDSP UMIK-1 will be required with that processor.
Flavio
Discussion Starter #8
Hello,
same as above :) you can use the Dayton UMM-6 with the standalone Dirac Live version while a miniDSP UMIK-1 is required in that case.
Flavio
Ok, thx Flavio for the clarification. That's a bit sad but not a big deal. Could you please explain if it will be possible to use the Dirac Live license for activation or if it will be possible to exchange them?
Discussion Starter #10 (Edited)
A.F.A.I.K that's not possible as they are different products even if the Dirac Live technology is exactly the same... also in general I imagine that's not something that people will want to do if they already own a more expensive Dirac Live 7.1 Full version because it can operate at higher frequencies and allows the use of two computers, has a DSP gain control and can be used with all measurement mics.
Sorry, Flavio
Thx again. Although it would be very user friendly, if you could use one of the two available activations from the standalone Dirac for the nanoAVR DL! :)
Does anyone know how the NanoAVR-DL handles EDID issues with devices using the HDMI interface?
I've got an AppleTV that's a bit problematic with HDMI, even with modern receivers. The AppleTV likes to stay on for a while before going into sleep mode.
With just 2 HDMI ports, would like to connect a HDMI switch to connect multiple devices. Which HDMI switches have been successfully tested with the NanoAVR?
1 - 12 of 12 Posts
