21 - 28 of 28 Posts
Discussion Starter #21
I have the subwoofer on casters. At 240 lbs the whole sub will move at high power. You're kidding about the foam right?
Scott
Super Moderator
I know he has built quite a few speaker cabinets and designs out of foam. I think I remember his SH was a foam model on the inside also.
Tapped Horn (TH) = positive flare, high sensitivity, narrow range, big enclosure, SPL.
Tapped Quarter Wave Pipe (TQWP or TQWT) = straight flare, mid sensitivity, mid range, mid enclosure, EASY build.
Tapped Tapered Quarter Wave Tube (T-TQWT or T-TQWP) = negative flare, low sensitivity, wide range, small enclosure, SQ.
"You can have low end extension, high efficiency, or small enclosure size. Pick two."
He used HR's [~infinite] corner [0.5pi] loading, which adds a theoretical 12 dB ref. to 2 pi, a gain that you won't get down low in any typical HIFI, HT room. HR's 1.0 pi is much closer to what you might get corner loaded in a heavily constructed house like is required in northern climes.
GM
Awesome build, thanks for all the pics, looks great. Hard to beat the SI woofers, just need to get more people to realize how good they really are.
+1
So it seems; a quickie sim for a ~15 Hz TH yields all the SPL my flimsy house can safely handle in <300 L net corner loaded/500 W/16 Hz:
GM
In the spirit of "more is better" and "too much is not enough" I built a tapped horn out of a Stereo Integrity HT15D2.
In testing, at 30Hz in the garage I stopped at roughly 14 watts of the 1400 available because I thought the garage door was coming off the rollers.
Scott
Nice build. :clap: I just printed it out for mine. Would you make any changes? seems straight forward. I wanted the mouth moved to the end, lying down flat. Haven't mastered hornresp yet so unsure if that is good or bad.
"I wanted the mouth moved to the end, lying down flat. Haven't mastered hornresp yet so unsure if that is good or bad"
I might know the answer to that one; makes little difference as long as the mouth exit has the same surface area and the sub mouth is at the same spot in the room.
The design shows off the driver beautifully and the available spl is stupefying . Different strokes for different folks though, l would have added another fold and sacrificed some of that generous spl for relatively more pronounced infrasonics may be down to 16.
Devil is in the fold though.
21 - 28 of 28 Posts
