1 - 3 of 3 Posts
Hello to everybody,
For some particular measurements up to 48 KHz I am trying to use my Focusrite scarlette 2i4 at 96 KHz on my macbook pro, but REW doesn't show that sampling rate, only 44.1 and 48 KHz.
Is a limitation of REW under OSX?
I can select 96 KHz on my Macbook pro and also on a DAW.
Thank you.
Yes, REW only supports 44.1 and 48k on OS X. It supports higher sample rates under Windows if using ASIO drivers. Although the OS X JavaSound implementation supports higher sample rates the results can be not at all what would be expected if the soundcard hasn't been configured to the higher rate being used. Unfortunately Javasound is unable to change that selection itself so there is a high likelihood of getting incorrect results, hence the limit in REW.
1 - 3 of 3 Posts
