1 - 20 of 25 Posts
What would be the recommended method to make Black Widow a bit darker?
I am pondering getting the new Acer H6500 projector which has good light output and I would really like to have some ambient light tolerance.
· Moderator Emeritus
Welcome to HTS! :wave:
While it's possible to darken BW™ a bit by adding Liquitex BASICS 'Ivory Black' (a max. of 10% IIRC), we actually are in the process of developing darker versions of BW™. However, it a slow process since we have to do it in our spare time and that is at a premium nowadays (life seems to speed up not slow down :gulp:).
Thanks Harpmaker. Is that "Ivory Black" the same as a bone black pigment?
If you use up to 10% of the Ivory Black, what gain do you expect to achieve? BW is around 0.88, but what if I want to get down to 0.4?
Have you looked into black mica pigments? "http://www.amazon.com/Dark-Black-Mica-Powder-Metallic/dp/B0040E981E" (sorry, can't post auto-links yet, only 2nd post)
How about a darker base coat?
I know, lots of questions, but I like to explore the possibilities. :D
Yes; the other major black pigment in artist acrylics is 'Mars Black' which is a synthetic iron oxide. 'Ivory Black' will result in a blue push to the mix if too much is used and the blue isn't corrected for, but it is less blue than 'Mars Black'.
Unfortunately, screen gain isn't something that can be guessed with any accuracy at all; too much goes into what produces it. First you have the gloss level of the paint base being used and then you have the added gain from any reflective element added to the mix. I could tell you what gain (or rather how much light the surface would absorb) for a Lambertian surface (a surface that reflects light in all directions equally), but when you throw paint gloss and reflective particles into the equation gain simply must be measured. It turns out that a N7 Lambertian surface would have a gain of 0.4 (would reflect 40% of the light that hits it). A N7 neutral gray paint, even most flat finish latex paints, would have a gain slightly higher than this since even they have some gloss. The more gloss and/or the more reflective particles that are added the higher the peak gain of the mix will be, but it doesn't take much to be too much and then hot spotting, or other negative optical artifacts, becomes a problem.
Yes, but when you start adding color to mica you decrease the reflectiveness. This is from the description of the pigment you give the link for: "This mica powder is a matte with a very slight shimmer". All the colored mica powders I have seen are either for coloring automotive paint (thus having large flakes that won't work for a screen) or making cosmetic powders (these lose most of their reflective qualities when added to paint).
This is the way we will try to go with our darker BW™ mixes.
We don't mind questions, questions are good. :T
Maybe a very dark neutral balanced OTS like Glidden Onyx Black would be useful.
Understood. It's a delicate balance of specular reflectance and Lambertian. The aluminum is really working well then to provide a gain of 0.88 and a Munsell value of 7.5. It would be nice to be able to achieve a paint with a gain of around 0.5 but a Munsell value of 4 or so. With today's light cannons, this would still provide a nice image in ambient lighting.
Yep, I haven't been able to find any reflective "black" pigments that retain their reflectiveness.
So, does this mean that you will need to make BW more transparent? I've been thinking about a dark neutral base coat that is glossy, covered with a topcoat of flat transparent BW. I imagine that the struggle will be finding the correct tinting additions to keep it neutral.
Thanks again Harpmaker. I will do what I can to ask more questions and provide input when I can. I've got a little experience in these matters.
If that color was truly RGB 30 then it would be perfect, but my experience is that as grays get darker they are harder to keep neutral. I'll get a sample of 'Black Onyx' next time I get to a paint store, thanks for the tip!
Yes, it's a combination of the aluminum and the gloss from the latex base paint. Most BW™ mixes we have measured have been ~N7.6 which has a Lambertian gain of 0.5. (0.499 if you're picky ;)).
An N4 paint would have a Lambertian gain of 0.11, I would guess getting that up to 0.5 without hot spotting would be tricky. Another problem that raises it's ugly head when mixes get darker is "simultaneous contrast", this is the contrast difference between the lightest and darkest areas of the screen. Think of it this way, the contrast difference between a white and a light gray is a lot less than between white and black. In the real world this difference can show up in a number of ways, for screens it's usually an appearance of graininess or a filmy layer on top of the screen that may or may not shimmer in light scenes.
While I won't take any technique "off the table" at this point, I doubt very much if increasing mix transparency is the right way to go especially if the mix contains reflective particles. While a transparent/translucent BW™ mix would allow light to reflect off aluminum particles below the surface of the screen those same particles could also block the light from the deeper flakes from escaping in a direction the viewer can see. It could also set up a condition where light reflects internally several times before either being absorbed by the screen or exiting on a plane that may or may strike the viewer eyes. This is one of the reasons why the so called "light fusion" screens advocated on another forum don't really work as advertised.
No problem! :T Would be share your past experience with us? If for any reason you don't want to do so publicly, feel free to PM me. ;)
I don't have the RGB for Onyx Black, just know it's from their neutral palette and is probably around an N3. I was looking through the Sherwin Williams colors and found Tricorn Black (SW 6258) which is 45 45 46. Not quite the 30 you would like but not bad either.
Well, you guys did really well getting from a Lambertian gain of 0.5 up to 0.88, but I'm sure making it darker it can be accomplished.:T I understand what you are saying about the contrast but hopefully more modern light cannons can overcome it.
All of your concerns are legitimate. I remember looking at the screenshots of light fusion and thinking that they looked "murky" or out of focus. If I can get around to getting a new projector, I would like to push the limits.
Past experience? Sure. I'll be open and transparent about my past :D I don't know if you or anyone else recognize my screen name from the Lumenlab forum. I was the guy who pushed the experiments utilizing colored pigments to create much darker screens, and I was working with a low lumen DIY projector.
In the process of doing that a couple of "enthusiasts" (I use the term loosely) came over from AVS wanting to also do some work on the idea. I stuck with the idea of using no to little titanium dioxide pigment. One of those AVS individuals pushed the idea of titanium dioxide, essentially turning it into a silver/pearl/TiO2 paint balanced with color components.
When I saw that I figured I could just go to the paint store and find a proper balance to the color pushes of silver/pearl. I backed out of the patent attempt because I knew it was a waste of time and didn't have any new science behind it and would be rejected on review.
Even after backing out, I negotiated to get a small cut of any proceeds but an official agreement was never completed, not for lack of trying on my part. I suspect some money was made but I never saw any of it, probably due to the debt incurred from the patent prep.
Anyways, over the last 5 or 6 years I've been mulling ideas over and over in my head without a projector to really play with. Hopefully that will change soon. Time to stop lurking in the shadows. :sn:
If you have any questions, I'm open to answering whether they be technical or about my past experience.
Discussion Starter · #10 · (Edited)
...and just to pique your interest...
These screenies were taken during 2005 (I believe :dontknow:) of my version of a black screen. This formula used silver and pearl mica based pigments plus various red, green, and blue pigments. There is NO titanium dioxide in the mix. Behr flat deep base was used to carry the pigments. This coat was spray painted over a standard primer coat. The projector is a LL style DIY job pushing maybe 250 to 300 lumens, floor mounted. Black screen is on the left, BOC on the right. First pic is with lights off. The "lights on" shots are obvious. The boxes holding up the screen are 18" wide so that puts the diagonal measurement around 75". All of the ambient lighting was coming from the right side of the screen. Pictures were taken from a seated viewing position (AKA on the couch:bigsmile:). I hope I remembered everything...was 6 years ago.
Inspiration for a new avatar :eek:
Ok, I ordered a new projector...ViewSonic Pro8200, one of the sub-$1000 1080p DLP units. A review at Projector Central states that it puts out 1145 lumens in the "Dark Room" setting in low lamp mode. I intend to run with these settings, or something close to it, to extend the lamp life. The projector will be ceiling mounted.
I intend to have a 92" diagonal 16:9 ratio screen. This would give me 45.5 footlamberts on a unity gain screen.
I want to use Black Widow, but with a gain of 0.88, it would give me 40.1 footlamberts.
Based on previous posts, my plan would be to paint a darker neutral gray base coat and then paint a top coat of Black Widow.
Any suggestions for the neutral gray base coat? How dark do I need to go?
I made the mistake of reading "base coat" as "base paint" before, sorry about that. The color of the base coat (the paint that BW™ will be applied over) will have little to do with the appearance and performance of the BW™ screen. All of our mixes are as opaque as we can make them so very little light makes it through 2 rolled coats (~4 sprayed coats) of paint.
To get a darker BW™ screen you need to darken the base paint used to make BW™. If you are interested in trying such a mix I'll start a thread in the DIY Screen Development forum. This experimental mix would be N6.6, have the same amount of aluminum in it and would be neutral.
With so much light hitting your screen you don't really need a reflectively enhanced mix like BW™, an OTS neutral gray would work fine. A paint tinted to match Glidden 'Veil' (~N7.5) would work well. Whenever you use a reflectively enhanced mix there is always the possibility that you may see some graininess in the image depending on the brightness of the image and how close your viewing distance is.
Discussion Starter · #15 ·
Base Coat vs. Base Paint...yeah, that threw me off.:doh: I understand what you are saying now and it made more sense to me from the beginning to darken the base paint. What you are saying is that you need to make the Bermuda Beige darker and properly formulated so that when mixed with the AAA the reflectivity will be increased and the color will be a neutral balance.
I would gladly take on the painting of a darkened version of BW. I just need to know what you are recommending for the base paint. In the short term I may use the Glidden Veil for something quick while I find the best place to get the AAA. Just so you know, I will be rolling, not spraying. I will be putting the paint onto a sheet of tempered hardboard and I'll primer with Kilz2.
I'll check out the new thread as soon as you create it :T.
I remember that. I believe the conspirators made a big deal of going over to LL before they returned in force to AVS.
It looks like you had an interesting mix back then. What did you do with the screen?
Discussion Starter · #17 ·
Eric, Unfortunately, that screen is long gone and I haven't been able to locate the exact formula since the LL website is now non-functional. That screen was far from perfect but showed that a very dark screen could work well, even with a low lumen beamer.
The screen was a blend of silver and pearl mica, transparent deep flat base, and additional color components that were there in an attempt to reflect RGB. The screen in those shots pushed blue so wasn't balanced. The idea doesn't work with more modern projectors because of the use of multiple wavelengths in addition to RGB. The new projector I just ordered is a 7-segment color wheel DLP. I now realize that best option is to have as neutral a screen as possible, reflecting the visible spectrum equally at all wavelengths. The most novel part of that screen was the lack of any titanium dioxide.
At some point I may experiment again with the same concept but adding the goal to obtain a neutral balance. In the 5 to 6 years that I have been watching DIY screens from the sidelines, the only real advance was the use of aluminum, which may fit nicely with my original concept.
For now however, I'll be going the route of a darkened BW screen so that I can spend some time enjoying the big screen. There are some other concepts rattling around in my head also but I'll keep those rattling around for a while longer :bigsmile:
Discussion Starter · #19 ·
That is cool.
I wouldn't dismiss your idea totally. Depending on the pj, one could develop a mix based on which way the pj pushes.
No, I haven't dismissed it totally, but one also has to consider the color of any ambient light sources and how they will reflect off such a screen. That is what makes the problem more complex and from what I know now, likely impossible with the available range of pigments. However, if you can filter certain wavelengths out of your ambient light sources...then maybe...but that is another can of worms altogether.
1 - 20 of 25 Posts
