I've had a ceiling light tray in my theatre since it was built..It's looking a bit worse for wear of late with some warp-age and swelling of the plasterboard panel..
I have an almost flat roof of "Cliplock" with very little space between roof and ceiling and certainly not enough room for anyone to crawl through..and moisture tends to build up in the cavity..
I decided to take it down and replace it with a centre ceiling light..
I looked around for a suitable light fitting from both local suppliers and on the internet and couldn't find anything large enough or of the style I was looking for..
I didn't want an oyster type light nor a pendant type..The style I was looking for (a more futuristic style) was only available in fairly small fittings..with very big prices!!
So I decided to make my own!..I originally thought of making it out of alum. which needed to be curved and folded..but in my neck of the woods, there are no sheet metal shops capable of doing the job..and I didn't feel like driving 200k just to get some metal bent..so I decided to make it out of timber instead..
The light source I will be using for the fitting will be a multiple string of 12v. LED's, in the order of 600 LED's..so there isn't going to be a heat problem using timber..
The light output will be controlled by an IR remote control dimmer, which will be programed into my Logitech remote..to be dimmed at the start of a movie..
One other thing I'm going to have to do is re-route my existing wiring for all the downlights and IR controllers, as they are currently wired to the ceiling tray!
I will post photos as I progress..
