1 - 4 of 4 Posts
Should I use the A-weighted or C-weighted scale of my hand held SPL meter when calibrating the SPL meter in REW? As a follow-up question, is there a cal file for the Extech 407730 meter? Not sure I need it, as I am using a Behringer ECM-8000 for the test mic.
Thanks!
Ted
OK, so C-weighted it is. And I assume that I should check the box for C-weighting in the dialog box in the settings on the Mic/Meter tab, right? That way they match is where my thinking is going.
Ted
Ooops, never mind. I had to read the instructions twice before I realized that I would use the C-weighted check box if I was using the mic in the SPL Meter as my input, but since I'm using another mic for my input, I should leave this box unchecked.
Sorry, not the sharpest knife in the drawer.
Ted
1 - 4 of 4 Posts
