A question about DIY class D audio amplifier
1365 Views 2 Replies 3 Participants Last post by  turboeclipse
I'm trying to DIY class D audio amplifier. I had a question about the design though. Since this is a single-supply class D amp, what does the low-side switch do? When the high-side is on, the voltage potential is VCC to ground, but low side just connects the speakers ground to the MOSFET ground instead of to a negative supply. Did I miss something? Thank you!
1 - 3 of 3 Posts
I too have been looking into Class D amps for a project. I find that there are three variations. The typical integrated type (all in a single IC package) use a single power supply voltage as you describe and are wired BTL or have a series capacitor coupled output. I thought the later went out in the 60's but its back in class D, primarily for automotive market, I think. The former, Balanced Transformer-Less, uses two outputs where each output sit at 1/2 the power supply voltage. (Is this dangerous?) The two outputs are driven out-of-phase producing double the AC peak to peak voltage to the speaker and theoretically four times the power for the given power supply voltage. Also very helpful for automotive or inexpensive amplifiers of 100 watts or more.
Then, finally there is the type which uses two power supplies (separate positive and negative power supplies like most analog amplifiers) for a ground referenced output. These often use external MOSFETs to produce a good power level in a "normal" way. I think most of the professional sound amps are this style.
So it all depends on which driver chips or power chips you use, and there are so many these days! Hope this helps.
It just means the zero output would be at half the positive supply rail. If the positive side is at 24V then the output at zero is 12V. A full-scale output sine wave would swing between 24V and GND with the zero crossing point at 12V. There are half-bridge, full-bridge, and bridged tied low output stage designs used for class-D. The most common used today is the full-bridge or H-bridge as it is sometimes referred to.
  • Like
Reactions: 1
1 - 3 of 3 Posts
