1 - 2 of 2 Posts
Hello,
Most A/V receivers come equipped with measuring microphones for automatic speaker setup. It is to be expected that these microphones are not linear and each receiver will match its own microphone response curve.
Assuming that the microphone curve is known, is it suitable for use with REW? ...or are there other drawbacks?
Thanks to all
Big assumption. If you can obtain the correction curve, they might work fine.
1 - 2 of 2 Posts
