1 - 1 of 1 Posts
I've been searching for a compatible unit to AB Switch with HDMI, Mac and 2 TVs.
I hope the info below will suffice for answering question of "how to connect successfully."
Here are the units:
Setup: Originating output, MacMini, Processor is 2.6 GHz Intel Core i5 El Capitan up-to-date.
TV1:
Viewsonic VX2252 mh series
LCD
Type
21.5" Wide Color a-Si TFT Active Matrix LED
Display Area
18.7" horizontal x 10.5" vertical; 21.5" diagonal
Optimum Resolution
1920 x 1080
Contrast Ratio
1000:1 (typ.) / Dynamic : 50,000,000:1
Viewing Angles
VIDEO INPUT
Analog/Digital
RGB analog (0.7 / 1.0 Vp-p, 75 ohms) / HDMI / DVI-D (TMDS, 100 ohms)
Frequency
Fh: 24~82kHz, Fv: 50~75Hz
Sync
Separate Sync
CONNECTOR
Analog/Digital
15-pin mini D-sub (VGA) / HDMI, DVI-D (with HDCP)
Audio Input
3.5mm jack (green)
Power
3-pin plug (CEE22)
AUDIO
Speakers
2-watt (x2)
POWER
Voltage
AC 100–240V (universal), 50 / 60Hz
Consumption
21.5W (typ)
Eco Mode
18.6W (typ)
Power Save Mode
15.8W (typ)
CONTROLS
Basic
Power, 1, 2, up, down
OSD
Auto Image Adjust, Contrast/Brightness, Input Select, Color Adjust, Audio Adjust, Information, Manual Image Adjust, Setup Menu, Memory Recall (See user guide for complete OSD functionality)
TV 2:
Samsung UN32J5205 32-Inch 1080p Smart LED TV (2015 Model)
Inputs & Outputs
HDMI
USB
1
Ethernet
1
Component
1
Composite In (AV)
1(Common Use for Component Y)
RF In (Terrestrial/Cable Input)
1/1(Common Use for Terrestrial)
Digital Audio Out (Optical)
1
Audio Out (Mini Jack)
1
Power
ENERGY STAR® Certified
Yes
Power Supply (V)
AC110-120V 60Hz
Typical Power Consumption
27W
Maximum Power Consumption
55W
Standby Power Consumption
Under 0.4W
1 - 1 of 1 Posts
