so im thinking about getting a set-up from css and im wondering how far away from a shelf/wall the PRs have to be?
well that rules the PR route out. if i was to use the ccs trio12 in the 4.5c^ft with the stated slot port how would it model with 300w? or maybe even 240w? just tryn to save a few bucks lol and my room is small 10x11x8 ft. and i want to do 2 subs. also do the bash 300 and PE 240 come with the required 18hz LFP? or would that need change based on the wattage difference? also where would i find the "base" values for these amps? ive looked all over and cant find where it says what they come from the warehouse with
What are the port dimensions that you're referring to?
Yellow is the Bash 300, orange is the Dayton 240 watt amp, both have a HPF around 18 hz. The Bash 300 has 1 db of boost in the 25 - 30 hz range.
