does anyone know what the watt rms per coil is on the audiopipe 15" TXX-BD Series 2800W 2 Ohm DVC Subwoofer
im tring to find out if one per channel can be powered by a the crown 1502 which puts out 550watts at 4ohms an 775 at 2ohms
im tring to deside if i want to run as a 4ohms 2 channell amp as depicked in the sonixeletronic Wiring Diagram
or is is it possible to run as a 2ohms two channell amp to 1 duel 2ohm for the left an the right channell
the amp has speakeron outputs but i dont know how to use them iv seen youtube vids say useing a 4 pole speakeron connector is one
way if thats true can one make a custom cable with 8gauge wire
