I feel like my acoustical treatments are lacking a bit and want to hopefully improve on what I have now. I also want to see if there is any need to do anything for my two channel setup.
My room is 19'6" wide x 23'2" deep x 8'6" high, with a 6" riser stage across the front and a 12" rear seating riser across the back.
Here is my current setup... all panels are from GIK Acoustics...
3 x 242 panels (24" x 48" x 3.5") on each side of the room that handle side reflections.
1 x 242 panel (24" x 48" x 3.5") behind each main front speaker. You cannot see it from the MLP (main listening position) because the front speaker blocks it.
1 x Monster Bass Trap panel (24" x 48" x 7.5") on each side of the rear (back) wall behind the surround speakers.
So at this point I have some 242 panels on the side and front wall and a couple of the 244 panels in the back.
I am considering adding a couple of GIK Spot Panels 24" x 48" x 2" on the ceiling at the first reflection points... or for about the same price I could get the 242 panels at 24” x 48” x 3.5”... although I am thinking the 2" thick panels might be less obtrusive and obstructive for the rear seat listener.
Those would be placed here... in black, which should also help in light reflection from the screen.
The first reflection points on the ceiling just happen to line up with the sides of the return air vent.
You can see I installed thin plywood covered with velvet, which helps tremendously with light reflection off the ceiling... however, where it ends and the paint starts, there is still light reflection there... although not that noticeable for the MLP. I know the velvet looks bad, but when the lights are off and the only light is the screen reflection, you don't notice them. The only time you can see them is if you use a camera flash.
I am curious about the Tri-Trap Corner Bass Traps from floor to ceiling in all four corners of the room. Would this help with the acoustics in the room and would it be worth the expense?
Also... is there any need for diffusor panels anywhere?
I would not have enough room for the 244's in the back if I installed the Tri-Traps. I could move those to behind the rear seats and place them sideways on the lower wall below the DVD/BD/CD shelving... or put them somewhere else... not sure. I may could use those in the front instead of the 242's behind the main speakers, then move the 242's to somewhere else.
I am also curious about any need for some type of acoustic panels for my two channel setup. I hope to be able to use the Cardas Room Setup Guide suggestions for placing my two channel speakers, which means my speakers will be well into the room... 5.5 feet from each side wall and 8.8 feet from the front wall. (For clarity sake... Cardas calls what I call the front wall the rear wall... it seems more logical to have a front and rear wall ... or front and back, which is in the rear of the room when sitting in the MLP... :huh: )
Here is an overview of the room and approximate two channel speaker placement. If I follow Cardas recommendations, then these may not be positioned just right on this drawing (I am sure I will try different placements anyway), but you get the idea.
I would appreciate suggestions and recommendations.
