1 - 5 of 5 Posts
This probably isn't the right place for this, but...
Doses acoustically transparent material as is used for speaker grills also let IR remote signals thru? I was thinking of using it to hide my electronics.
Thanks
Moto
Hmm, interesting question. It should work... but i suggest trying it with a small piece of the exact grill cloth material you want to use before you make any major investments.
Yes it works. No problem whatsoever.
Went to Walmart and bought 60" x 10 yards of some cheap black thin cloth for testing. I can only assume that actual grill cloth is even thinner so it will also work. I may have cut my highs slightly since it is covering the center channel also. I am going to rerun Audyssey, but I could hardly tell the difference from before and after.
Thanks for your help
Moto
1 - 5 of 5 Posts
