1 - 4 of 4 Posts
You can use the 16". Just then 3 panels is the same width as 2 of the 24's
More coverage isn't always better. If you're using for reflection panels, then likely you'll need the full width.
Lots of people spend lots of money on things that aren't right sometimes. I wouldn't want any more damping than required to reach the target decay times.
What are the ideal target delay times?
It's based on your room volume. Then you have to take into account how the room is constructed, # of people, furnishings, etc. There isn't just a single number.
1 - 4 of 4 Posts
