acoustic room question
563 Views 8 Replies 6 Participants Last post by  tezz
What are the key factors to consider when designing an acoustic room for music production or sound recording purposes? How does the size and shape of the room impact the acoustics and what methods can be used to mitigate
any negative effects? How can materials such as wall insulation, ceiling tiles, and flooring impact the sound quality of a room? Is it necessary to use specialized acoustic treatment such as bass traps, diffusers, and absorbers, and how
should they be strategically placed within the room for optimal sound quality? What role does room resonance play in the sound of a recording, and how can it be adjusted to achieve a desired sound? How do room reflections and
reverberation time affect the overall sound quality, and what techniques can be used to minimize their impact? Finally, what are some common mistakes to avoid when designing an acoustic room, and how can one ensure that the final result meets the desired acoustic goals?
1 - 9 of 9 Posts
thanks in advance for any help
Brightness and Lamp Life
A dark room can have a clear image due to the 2000-lumen brightness of the Bauhn LED projector. To get a better image quality, you might need to close the curtains or blinds if you want to use the projector in a brightly lit space. The projector’s light life is up to 30,000 hours, so you can use it for a number of years before changing the bulb.
https://fineprojector.com/bauhn-led-projector-review/
  • Like
Reactions: 1
Every dimension of the room has associated "modes". For example, a room might have a dimension that produces modes at 60, 120, 180, and 240 Hz. Let's say the dimension is 16 feet. If a second dimension is also 16 feet, then you double the magnitude of the modes. If the ceiling is also 16 feet, you triple the magnitude of the modes. This is bad. The room will sound best if the modes are spread-out. I made a spreadsheet using room modes to help me pick the dimensions of the theater room in a house we had designed by an architect. I ended up with 10.5 foot ceiling height (flat), 19.5 foot width, and 23.5 foot depth. That room sounded different than every room in the house, even before it was finished with drywall. Next... you don't want dimensions that are all divisible by the same number... so 8x14x18 would be bad because each dimension can be divided evenly by 2. That will cause modes to stack-up also. 9x12x15 is also bad because all 3 dimensions are evenly divisible by 3. 9.5 x 11 x 17 would be better.
The other major factor is absorption and scattering of the strongest reflections. Put a mirror on the side wall. Sit in the main seat. Have someone move the mirror until you can see a speaker in the mirror. That's a reflection point. You can use a diffuser on some reflections, and an absorber for others. Absorbers work best for anything beside and in front of you. Diffusion works better for the sound behind you. Diffusers have unequal/uneven reflective surfaces. Absorbers grab sound and trap it to remove the reflections.
Next, long expanses of ceiling or wall (or floor, if it has a hard surface) are really bad for echoes. Do as much as you can to interfere with long expanses of unbroken wall, ceiling, or floor. There are decorative "beams" made for interior ceilings. Those can be wrapped with fiber-fill and then be wrapped with a loose-weave fabric to allow sound to get through the cloth and trapped in the fiber-fill. It's surprising how much better a room can sound without audible echo in the seating area.
Never use too much absorbtion or diffusion. Sound quality will actually get WORSE if you over-do either one. There should be a nice balance of absorbtion and diffusion in the room.
so much to see and do..
a few starters on the journey
edit: after several years of research and designs, I found a pro to do the hard yards.
Benefits - tailored design, ”right size” is critical, as when done properly, only minimal traps/diffusers etc are required, and you only get the materials required. That ‘right size’ may be large.
A good designer will sort out Local Codes, as well as the right combination of Acoustic internals as well as structure isolation to keep noise in and from getting out to keep the neighbours happy.
Lots of questions and lots of possible answers. If it helps you get started, look up the following:
The Golden Ratio. This will guide your room dimensions and potential listening positions.
Treating first reflection points. Catching your strongest reflections will provide a huge benefit for monitoring accurately.
Wholistic acoustic treatment. This is a general approach that will tell you what percent of your reflective surfaces should be treated with absorption and diffusion.
There is a wealth of information out there. Good luck!
Lots of work done on optimal room ratios by University of Salford in UK.
A guy in Gearspace did the hard yards to put these into an Excel format.
this link is to xl, and Salford research, might make life a little easier.
it even got a tick from John H Brandt, mentioned in my earlier post.
gearspace-salford-excel
while there’s golden ratio, a number of earlier acousticians developed preferred ratios, however most earlier work related to larger spaces like concert halls, auditoriums etc.
Salford’s research by Professor Trevor Cox is specifically intended for ‘smaller’ spaces, and was used by BBC
Sounds recording is often done in what is called a Live Room, in the sense that sound is created "live" in that room. The size and materials used in such a room, and the acoustic goals, are often quite different from the room in which one listens to the recording, and mixes and masters it. The is often called a Control Room, and has different properties, and acoustic goals.
Things like "golden ratios" in terms of the room size and construction can make a difference.......and many of the best sounding rooms don't conform to any specific shape, but are well treated and well set up. If you have the money to build a room from scratch, including choosing the dimensions of the walls, floor and ceiling, and the materials used, you probably want to spend the first ten thousand dollars of your 200 thousand dollar budget on a expert like PMI engineering, in Marin County, California, or similar, so that you get it right.
But to get a sense of what it takes and what to discuss with the architect and builders, or if this is a DIY project, this book is the best source to start with:
Home Recording Studio: Build It Like the Pros 2nd Edition
by Rod Gervais
Nathan is correct in that studios have more life than control rooms, and many have variable acoustics for different styles of recording, and indeed the different acoustics provide a ‘signature sound’, eg Abbey Road.
The Salford ratios are related to Control Rooms specifically.
Rod Gervais‘ book is excellent, and on my shelf, as is the more introductory one by John H Brandt, both regular contributors on Gearspace Acoustics forum, along with a few other professional acoustic designers.
From experience, and if there’s available space, a larger room with the right dimensional ratios will reduce specialised and expensive treatments.
In my 6m x 9m x 4m room there’s only 3 devices, all on the back wall. The rest is common house insulation and 25mm sheets of Rockwool, simple enough for DIY installation.
1 - 9 of 9 Posts
