21 - 40 of 41 Posts
I've seen some interesting plans for 2-3 way speakers that use active crossovers.. By active crossovers, I mean Behringer DCX2496 or some of the cheaper models.
However, with active crossovers and separate line level outputs - with a pair of 3 way speakers, you're looking at having 6 sources to amplify. What do most DIY builders do - when they need to amplify 4-6 channels for a pair of speakers?
Multiple pairs of amps? Or a multichannel HT amp?
Or...... are active crossover arrangements that uncommon because of the issues with number of amp channels needed.
Last year I upgrades from passive to active. My project was to convert my LCRs from a 2 way passive system to a 2 way Active system. Because I have 3 identical LCRs, I would need 6CH of amplification. The challenge I faced was finding a suitable crossover to match my driver layout. These speakers have to fit into cutouts that are part of my baffle wall behind my AT screen, so it wasn't going to a case or a complete redesign unless I changed the baffle wall as well. I needed to find an active crossover close to the frequency I was using in the passive system in order to maintain the same driver spacing that controls the vertical dispersion of the speaker. The passive system uses 1550Hz which was proving to be a challenge as all the products I saw used higher crossovers.
Basically, as I searched the net for active crossover, I found a few products that would do the job, however hideously expensive by the time one added amplification. I even turned to JANDS who make active modules for JBL powered speakers and no luck on anything "affordable" as the cheapest units they had were over $1000 each.
I contacted the speaker company I buy my drivers from and asked what solutions they could offer. As it turns out, they were testing a small 2CH module with a 2K 4th order LR crossover and they seemed impressed with what they had. These modules have 70W LP and 30W HP and a 2K crossover. They praised the product, so I took a leap of faith and bought 3 units.
To convert my speakers from 1550Hz to 2000Hz meant I had to reduce the centre to centre spacing of the tweeters. I elected to have a new set of baffles made out of ABS plastic as opposed to the making new baffles from 25mm MDF. I also made myself some new trapezoid enclosures. Doing this added a few liters to compensate for what the 2CH amp module would take up as well as giving me the proven benefits of such a shaped enclosure - IE the two side walls are no longer parallel.
The key being that in order to reduce the spacing, I had to over lap the drivers, so counter sinking the centre driver. I built my first speakers with controlled vertical directivity in 1998 and this is actually set 5 for me. Because those designs worked so well, I've continued to do the same thing for the different designs including these current speakers.
Because my drivers are wired in parallel and the VIFA XTs I use a 4ohm, I had to make impedance matching for the HP section. The two woofers were 8ohm, so no problems there. Even though I use an 80Hz crossover to the LCRs, I still used a simple impedance network on the LP section.
The modules are basic. They have a single RCA as the input and they have an IEC (jug cord) power socket. There is HP/LP trims and a power switch. The end result is they work well. They play loud and deliver greater dynamics than the previous passive speakers could offer.
Image 1: A simple diagram showing amplification after the crossover.
Image 2: The back of the Amp module.
Image 3: I used a double binding post terminal plate to connect the four wired from the AMP modules. Notice the bridging straps are removed. I then mounted the other components needed to back of the plate and this then was attached to the inside of the enclosure.
Image 4: New and Old side by side.
Image 5: The back of the L and C speakers once the LCRs were installed back in the baffle wall.
Discussion Starter #22
Very interesting Mark. I recall seeing that you had to change the spacing of your tweeters but didn't fully understand that it was due to a change in your crossover frequency.
I am going to post a build thread....but I'm working on a 3 way build.. I have a few Crown Microtech amps and for the short term going to use a JBL M553 (a 3 way stereo crossover). I plan on upgrading to a DCX2496 or DBX Driver PA+ and maybe QSC DCA amps to replace the Crowns.
Your setup looks great - especially with the modules. I'd love to buy some Digmoda modules....but they're not cheap and unfortunately Speakerpower is OEM only.
You said Vifa treaters...what did you use for woofers?
The drivers are all VIFA (XT super tweeters and P17 woofers) and infact the tweeters actually have "MADE IN DENMARK" on the magnetic shielding cups (yes I used shielded drivers as well).
Late 2009/early 2010, I built two sets of the older passive design and the same model speakers have now "DESIGNED IN DENMARK". I am therefore left to assume that means made in China. Even so, China can produce some very high quality products and these drivers looked exactly the same and sounded beautiful once the systems were completed.
As I understand it, VIFA and Peerless combined to produce PEERLESS AUDIO ENGINEERING (AKA PAE) and all the line are made in China, yet they perform well.
Yes the 2CH amp modules are neat and take out the excess cable mess that I had when I ran a car electronic crossover for bass management a few years ago. This is very PLUG N PLAY now.
I've always been a fan of vertical directivity and thinking back, I've had some form of that for every speaker I've owned (hmm interesting). So it was just a case of working out what I needed to do to make it happen.
So a three way? Single W M T or something like W MTM W? And yes, having heard the same drivers in a passive system, then active, the active is the way to go. Clean, powerful. I think I might have to go out and listen to them now :)
With all the talk of the extra amp channels needed it got me thinking of how many i'll need, after the math i should have more then enough: 2 UPA-5's 1 XPA-5's and 2 XPA-1's that should be plenty enough to do 3 amp channels per speaker (L-C-R). One thing after reading a couple posts here is that i relized my tweeter is 4ohms as well as my mids, will that present a problem i'll need to over come or will i be good to go? my active crossover is a DCX2496.
Discussion Starter #25
Do you really have that much Emotiva gear? If so - I'm jealous! I have a UPA-7 which I love.
I think that almost any Emotiva gear can handle 4 ohms without a problem.
I think the one thing that you might run into - is whether you can cut the 4 ohm drivers enough to drive them at a similar level as the 8 ohm ones --- or boost the 8 ohms enough to get them to match. I think unfortunately, you can't adjust the gain on each channel of the Emotivas.
You thinking 2 or 3 ways? You'll need at least a couple more DCX2496s, I think.
Discussion Starter #26
That's interesting aboue PAE. I recall reading about some recent(ish) changes that have occurred - regarding where they are actually made.
Yup........ a WCW
AE TD12S - Coax (B&C 8CXT) - AE TD12S
Crossover and EQ will be a bear, but should sound great!
Discussion Starter #27
That's interesting about PAE. I recall reading about some recent(ish) changes that have occurred - regarding where they are actually made.
Yup........ a WCW
Emotiva certainly makes some good amps and with there sales they have had lately it makes them hard to pass up (I think it's OCD,LOL). I'm not so worried about the amps being able to deliver as i am the level matching, i'm doing 3-ways with the center possibly being passive but haven't set that one in stone yet. I too wish there was some sort of gain control on the amps, who knows maybe the DCX will have some sort of feature like that i haven't had a chance to play with it yet and it will probly be a few months before i am able to actually sit down and mess with it as i like you have 200 projects going on top of hanging with the twins.:sn:
For a 3 way active system, you will need 9 channels of amplification or three per speaker.
I run 2 way LCRs, so I use 6. Some day, I'd like to extend that level of performance to the surrounds as well. I can only imagine what a active 3 way LCR array sounds (or is that pounds?) like :) My 2 way LCR array lets you know it is running I can tell you.
Looking at the WES catalogue, it does appear that PAE is made in China. I am assuming the other VIFA and Peerless drivers are made there as well now. I choose VIFA because they were (at the time I started buying them anyway) made in Denmark. I'm sure the XLS woofers I use in my SUBs also have a place of manufacture as Denmark as well. I didn't see that on the last two sets I made.
Yup........ a WCW
Bear, is that the brand?
So is the mid/HF coax driver able to be powered separately or does the HF driver leach power off the Mid's amp and use passive components for for the Tweeter's LP and Mids HP?
In my system, I have a 70 watt amp and a 30 watt amp. The 30 watt Amp drives the three tweeters with signal from 2K and up. I had to add resistance in series to the tweeters to bring the load back up to 4 ohm from 1.3ohm. These amp modules are actually designed around an 8ohm load (as are most AVRs), however I've been running 4 ohm loads now for 11 years and not fried anything yet.
So with my mids and tweeters being 4ohms and the bass units being 8 do you think i'll have to add anything to attentuate the volume of the drivers or to get all the impedances to match?If so what would i use?:dontknow:
Thanks Jim for letting me Hijack your thread by the way. LOL.
Discussion Starter #31
Sorry! Meant bear as in tough!!
Crossover temporarily is JBL M553. Going to upgrade to DBX Driverack PA+ or DCX2496. The JBL is very limited. You pick crossover frequencies - and you can change gain for low/mid/high - but that's it.
I'm actually planning on going entirely active. Yes, it means more amps and more cabling... :hissyfit:
The coax mid/HF drivers are completely separate and require a crossover.. I forget what the efficiencies are - but it's a few db.. Enough that I've not given a whole lot of thought to trying passive. The HF driver actually radiates through the fabric dust cap of the midrange.
I am not familiar with your design, but if it were my own, I'd be using two 8 ohm woofers in parallel which is then a 4 ohm load and up to 6dB more efficient than the single 8 ohm driver - basically, the amp does not have to work as hard to achieve the same SPL. Because you are going active, each band is managed independently, so you can run 4 and 8 ohm loads without incident. There should be trims on the HP to allow you pull down the level if it is too high. Drivers pending, you may need to install a passive L pad network to attenuate the HFs. In the case of my 2CH amps, they rely on this and why the HP section is just 30W. It needs the tweeter to be louder then the woofer. In my case, I made up that extra gain by wiring three XTs (they are only about 91dB, most tweeters are 94dB) and the three have given me some 8dB gain. Because I have used series resisters to bring the 1.3ohm load up to 4 ohm, I got a loss which has worked out to be pretty much right.
If you can wing going fully active, don't bother with passive - phase changing, power robbing etc etc etc. The only reason most speakers are passive is cost. It is not even case of simplified wiring as mine have a single RCA in only, so provided the AVR has full pre-outs (all THX certified AVS do), it is all good.
Discussion Starter #33
I have an Onkyo PR-SC886 w/RCA and XLR pre-outs... so I feel like I'm in pretty good shape to "play".
It was fun bundling 450 feet of speaker wire into 3 bundles of 3 runs each (Low/Mid/high cables in each bundle, and 3 bundles because of L, C, R). I did 50 feet runs so I have plenty of distance - even though it's way overkill. I wanted excess so I can figure out where I'm putting everything! So.. you talk of simplicity in wiring with your modules.. Yep.... That's for sure.
My original plan was to mount the 2CH amp modules in the EQ Rack and run extra cables to the speakers. I figured this might be OK, however as I went along, it was more of a pain than anything and I figured that since the SUB runs an RCA to its built in plate amp, why not do the same for the LCRs? And so that is what I did. All I had to change in my room was the RCA terminal plate (from single to multi) at each end of the room and run the 3RCA leads. I already had filtered power at that end of the room for the SUB, so that was a non issue as well.
The bonus is that should I upgrade my AVR (and I will for 3D at some point soon) to have Z or height channels, the speaker cables are already in place. And I have over 200mm (8") of space above the screen, so a perfect place to mount them too.
I use active crossovers (miniDSPs) for all front channels. I have ten channels of amplification for my 5.1 surround setup. My amps are Emotiva and deliver anywhere from 140 watts RMS to 300. Getting it wired up was very complicated for me, I burnt out a tweeter while doing it. But even with the challenge of getting every driver hooked up with the same polarity and correct channel the sound benefits are tremendous. With the same brand of amplifier getting the levels correct is easier.
Discussion Starter #36
Since Emotivas don't have a gain knob for individual channels.. I assume the miniDSPs allow you to change the level of the signal enough - to level match the individual drivers?
Yes of course. The miniDSPs have both input and output level controls. The output at max matches the Emos perfectly.
The one problem I''m having right now is that the output voltage is only .9 volts, just right for the Emos but too low to use a pro amp on the subs.
Discussion Starter #40
Cool. Thanks for the feedback.
My concern wasn't just changing the gain.. but changing it ENOUGH to match the drivers... Since some drivers can be quite different in terms of efficiency.
Thanks!
21 - 40 of 41 Posts
