Not trying to be rude, but it sounds like a lot of smoke and mirrors to me. A case of "Emperor Goo's new clothes."
I'd be willing to bet that Liquidtex (or Lowes/HD paint department tints) could tint white Goo to acheive similar results as Gray Goo. My only concern would be that it might require adding drops of a few colors in addition to black to achieve the desired neutral gray. Most of the neutral N8 and N9 shades, are composed of drops of 2 or 3 different colored pigments added to the white base. If you could take a sample of Winter Mist, or another known OTS neutral gray into Lowes... along with a quart of white Goo base, they can measure it on the X-Rite color matching computer to determine exactly how many drops of each pigment is needed to to make it match the neutral gray shade you have a sample of. They (Lowes & Home Depot) have this function built into their paint mixing systems, so that they can add pigment to an existing can of paint (to correct the color) if they initially got the color recipe a bit wrong.
Not sure if I'd tint the top coat though. I'd speculate that Goo acheives some of its gain boost with the translucentcy of the top coat. I'd suspect that tinting the top coat would destroy its ability to increase gain. If their topcoat truly is grey, as one of the senior members suggested.... then maybe there is something to Goo's claims.
I'd assume that Goo only wants us to believe that they use a blend of unique and exclusive ingredients. If the public stops believing this... then nobody would pay Goo $120 for 2 quarts of paint anymore.
Of course, I could be completely wrong and this might very well ruin your Goo. However, it would be interesting to try it, if you had an extra quart of Goo. A half quart would probably work as well. You would simply have to have the Lowes employee reduce the drops of pigment suggested by the X-Rite for a quart, in half.
