Hi all,
When I first got my 3805 together with my B&W 604s3 speakers, I used the Audioholics suggested workaround to get my Denon to bi-amp the front speakers. I was impressed with the difference.
Then last year I purchased another pair of B&W 602s3 for a 7.1 set up, and hence I needed to un bi-amp the 3805. TBH I have found the 7.1 set up to be significantly better for sound stage image steering than the 5.1. So I kept with the 7.1 set up.
Now I want to bi-amp the fronts again by using a separate power amplifier.
In the "old" days Denon produced the POA-T10 as an external amp for the AVC-10SE (I think that's the model) to get 7.1 amplification instead of the 5.1. These are like hens teeth to get hold of, and expensive.
Question: What technical features or specifications will I need to purchase in order to ensure my 3805 and a new external power amp are matched as closely as possible?
Obviously watts per channel is a good starter, but I imagine details like signal to noise ratio, input sensitivity of the power amp, output voltage of the Denon etc, will all have a bearing on the matching of a power amp to the Denon.
As an indication of tech specs, this is my Denon's details:
• Analog
Input sensitivity / input impedance: 200 mV / 47 kΩ/kohms
Frequency response: 10 Hz ~ 100 kHz: +0, –3 dB (DIRECT mode)
S/N: 102 dB (DIRECT mode)
Distortion: 0.005% (20 Hz ~ 20 kHz) (DIRECT mode)
Rated output: 1.2 V
• Digital
D/A output: Rated output — 2 V (at 0 dB playback)
Total harmonic distortion — 0.008% (1 kHz, at 0 dB)
S/N ratio — 102 dB
Dynamic range — 96 dB
Digital input: Format — Digital audio interface
• Phono equalizer (PHONO input — REC OUT)
Input sensitivity: 2.5 mV
RIAA deviation: ±1 dB (20 Hz to 20 kHz)
Signal-to-noise ratio: 74 dB (A weighting, with 5 mV input)
Rated output / Maximum output: 150 mV / 8 V
Distortion factor: 0.03% (1 kHz, 3 V)
Your invaluable help will be greatly appreciated!
Bob
• Analog
Rated output: 1.2 V
• Digital
S/N ratio — 102 dB
Bob
