1 - 11 of 11 Posts
I was experimenting last night with my MTM towers after reading a post on partsexpress techtalk. The post was talking about omni directional listening and the effects of the 3d image received from said setup.
So, i got to thinking and added a set of soft dome tweeters to the back side of my towers in the exact spot as the fronts but just on the rear. This creates a bipolar high frequency system and all I can say is WOW!!! My top end completely woke up. The more defined stage and image with the dimensional sound is so awesome!!! I sampled all my test and reference discs this morning before work and music is awesome, transformers..., what a difference it made.
I think the key was making sure the polar patterns didn't create phasing issues and aligning them equally was also a major component. I did try to match efficiency and got lucky that a set of new tweeters were just laying around my office. Bipolar setups do make a difference, now what if I could do the mid woofers too.....:nerd:
One trick is to use an L-pad with an ambience tweeter (or wide-band driver) so you can "dial it in" to match your room requirements. Congrats on your successful experiment. :)
Hello,
Very cool. It is amazing what tweaks and proper setup can do for getting the most out of your Speakers.
I use Martin Logan Electrostatic Speakers that are naturally dipoles and because of this require them to be setup 3 feet minimum from the Back Wall to get the best sound because of this.
Cheers,
JJ
Very cool. So you are liking it with movies and music? Are you only using towers, and not a 5.1 or7.1 system?
Matteo
Matteo
bi-polar is really a way to overcome the limited sweet spot of stereo. I don't suggest it for surround systems.
Great idea. Have fun. Dennis
Discussion Starter #8
^^My setup is a 4.2 system with my mains 60" apart and listening spot 11' back. Everything sounds awesome so far. My towers have a MTM with 4" on top and 6.5 on bottom.
I think building a set of TriTrix (partsexpress) with matching drivers on the fronts and back would be sweet. I could almost seperate those enclosures and add a 12" with 12"passive radiator to mimic a set of Definitive Tech's.
I run VMPS FF3SRE that have a 53in open baffle planar midrange driver that covers from 280hz up to somewhere like 8000hz before ribbon tweets take over and I lve the sound, I also have Innersound Eros MKIII Electrostat hybrids in storage that were great for mains but had a limited sweetspot so I pulled them.
I like di and bipoles for sides but prefer standard speakers for rears in 7.1.5 different people will likely have 3-5 different views on surround speaker implementation.
I'd start with a sealed design. The TriTrix is a TL. Omni-polaring it is a no-no.
1 - 11 of 11 Posts
