1 - 7 of 7 Posts
I posted this in a subforum but I don't think it got any traffic.
Right now I purchased the Asus vh242h 23.6" 1080p monitor. My apartment uses some dish network setup that gives analog "cable" channels via coax included in my rent money. I don't have the money or the interest for paying for FIOS/Comcast etc or getting a DVR with hdmi and using that as my tuner. A seperate tuner box would also let me hook up my ps2 to the monitor I think.Would one of those kworld style tuner boxes be a good solution for using this monitor as my TV as well as my monitor? Are those tuner box solutions any good?
This type of monitor makes a lousy TV due to the fact the they dont have a built in tuner and because its not a true PC monitor it is not ideal for that either, an external tuner from the PC is your best option but gets costly in a hurry there is no real cheap solution.
A KWorld TV Box 1680 EX is $60. Has some rough edges but does do what you want.
Explain how its not a true PC monitor?
I am thinking Ill just live with my 20 year old crt tv until I graduate then.
I have a 24" Westinghouse LCD hybrid monitor HD TV which works fine as either. I usually play 1080i upconverted DVDs on it and the picture is very good. Unlike the Asus you are looking at, mine has no speakers, but I run the audio through a stereo. A KWorld TV Box 1680 EX would allow you to access your cable TV signal and play it through the Asus VH242H.
LCD TVs do not scale video well and thus if you using it for anything other than its native resolution (1920×1080) your not going to get a very nice picture, PCs usually dont support this setting right out of the box as its a 16x9 display so there will be some scaling or the image will have black bars on the sides in order to fit when using it as a PC monitor.
PC monitors work well for PCs and TV monitors are ok for TV but only at its native resolution.
Thats too bad because my dell laptop supports 1920x1080 and its a basic 2 year old latitude. Looks great on this monitor.
1 - 7 of 7 Posts
