Have you gone into the user menu and selected analog for the CD input?
That's what I thought too...should be easy. I will try to find a stereo rca to 3.5mm cable to test the player via the front aux port, which I know works because I tested it with my mp3 player during setup. The cd changer worked the last time I used it, was connected to my old stereo receiver which I gave away. The cd changer just sat in the same spot in the audio cabinet for couple months, was never moved. Maybe it is the player & it just died while sitting unused and unplugged, but that seems strange. Will post back my results after testing via aux port. Thanks for the advice.That should be working, I would try connecting to the aux inputs on the front & see if that works. Do you know the CD Player works?
