1 - 4 of 4 Posts
I'm new here and need advise on my stage i built.Why do people put sand on the end of the stage and installation in the center.For my riser do i put installation in between too.I'm going with a 12"riser does it sound right.Thanks.
This is the stage.
A want to build a set of risers,with some lights and buy two more chairs.Any Advise Thanks
Sand is used in the stage to stop it from resonating when you have a sub and speakers sitting on it.
Insulation should absolutely be used in your seating riser to keep it from acting like a big drum.
Bryan
+1
I am considering a stage but my room in on concrete, so my stage will be in front and not subject to speaker resonance, I am going to fill it with insulation so it will act as another base trap.
Risers, build a riser for the nessasary height you need for rear seating, and fill it with insulation. Cut vent holes in the front face. Don't over pack it though.
1 - 4 of 4 Posts
