Yep first listen was over the weekend. Great R&B stuff. Always liked Jeff.Blow by blow? The first - and in my opinion the best - Jeff Beck album! How can you not like Freeway Jam and a song called Constipated Duck?
Hiya Jim! I wish I were a magician I’d go to Hawaii/Spain/Italy, etc. 🤑It's like they're floating in the air. Are you a magician too? 😄
There was indeed a time when the Energy subs were considered a good value, but for a mere $10 you easily eclipsed the definition of the words "good value". Excellent score!Heya Jim lookey here.👏 thrift store find.
Always heard these Energy subs were pretty good, so for $10(350.00 new) why not. This thing is well built with a nice hard rubber on the driver and well made speaker connections are a plus.
Thanks man. Look at this local distraction. Man remember I won it? Then sandy sank it. Funds are low these day, so sadly gotta pass.There was indeed a time when the Energy subs were considered a good value, but for a mere $10 you easily eclipsed the definition of the words "good value". Excellent score!
Oh come on man.You should consider posting a picture with all your gear. By now the house must look like a Best Buy showroom. 😋
Whoa just looked it up! 18 inches of bumpin’. Looking forward to your review.JTR RS1.
Well, you asked what my subwoofer was not what the current review unit is.Whoa just looked it up! 18 inches of bumpin’. Looking forward to your review.
It gets even better, my room is just under 1,800ft^3.Wow Jim! Good for you. Iirc your room is like 2400cuft? Hoot dang!!!
Whoa awesome! That’s a big a$$ room. That sub is killer I bet! Thanks for the link. Next question which speakers are you using?Well, you asked what my subwoofer was not what the current review unit is.I won't be reviewing the RS1 but I did do an informal write up that you can find at this link.
It gets even better, my room is just under 1,800ft^3.![]()
I don't know if 13x17x8 could be consider medium let alone large. Remember, ft^3 is cubic feet not square feet.Whoa awesome! That’s a big a$$ room.
I have about half a dozen sets of speakers, mostly so I can have something to match any subwoofer I might be evaluating. I rotate them around but frequently it's the XTZ M6.Thanks for the link. Next question which speakers are you using?
Wow! It does get better! I’d say you should add exactly one more to help keep that response even. R. O. F. L.Well, you asked what my subwoofer was not what the current review unit is.I won't be reviewing the RS1 but I did do an informal write up that you can find at this link.
Larger than mine for sure. 😢😀Whoa half a dozen speakers gotta catch up to you!I don't know if 13x17x8 could be consider medium let alone large. Remember, ft^3 is cubic feet not square feet.
