No, as both I and weverb have said, use the GRAPH LIMITS button to set the correct graph axis. The button is clearly marked GRAPH LIMITS.
For subwoofer plots, always use the standard Vertical graph axis of (45dB - 105dB) and the Horizontal graph axis of (15Hz - 200Hz) using the Graph Limits button in the top right corner of REW. Use a measurement start frequency of 0Hz and an end frequency of 200Hz. Use the appropriate target line that matches your crossover.
For full range plots, use the standard Vertical graph axis of (45dB - 105dB) and the Horizontal graph axis of 15Hz - upper limits you desire (or your mic/meter is capable of measuring), i.e. 15KHz - 20KHz. Use a full range target line.
For full range only, enable smoothing (1/3 octave) to eliminate the comb filtering.
Evening brucek
Oh, crumbs I think the crossover on the Eltax A12-R sub bass is -12db or then again it might be -24db?
As for the JBL 4645 the only crossover that’s used now and then is when I switch the SW-RE-MIX mode ON to divert the lows from discrete Dolby 4.0 or Dolby stereo 2.4.2 matrix.
When in Dolby stereo digital discrete 4.1/5.1 I switch the SW-RE-MIX to OFF. So it basically doesn’t have crossover I haven’t had the money to buy for a while.
When in SW-RE-MIX mode it applies crossover to keep the LCRS down at minimal as otherwise the directional tones will be audible!
I’m pretty sure its -24db down as the AVR is THX product and its usually standard 80Hz -24db.
I have selected the 1/3 but have toyed around with it, just curious.
It’s too bad I don’t have the same EQ all around to deal with some minor issues. I was thinking of saving up and buying a few more FBQ2496 for LCRS as they are cheaper than the DEQ2496 and REW can easily adjust the differences. Only downer is its only 20 bands thou I could loop the FBQ2496 to give me 40 bands that’s 9 bands more over single channel on DEQ2496.
I’ve just selected 1280 1024 no that’s not a sub bass it’s the monitor settings as I have large monitor. All the text is like the size of an ant!
But at least the site fits the screen smartly.
