10 db boost for subs is a lot of power. You need to make sure that your sub can handle the boost, and that you have clean power to do it.
Good for you, for figuring that out. :T The process has always been to EQ as needed, then adjust the sub gain afterwards, as it typically needs to have the level re-set after equalization. I typically use two-channel as the reference for sub levels, but admittedly with a lively movie that has all channels generating at once, a two-channel reference might leave the subs too low.[*]If generating REW PEQ's do you crank the sub level 10dB after measurements (doesn't make sense to me)?
Generally, it is. I’ve never been a fan of rigid numbers like this, because the amount of gain in sub level needed (if any) is very room dependant, and also on user preference. That said, a boost in the 4-8 dB range is common, with the 25-30 Hz shelf in sub response being about that much hotter than what is measured at the crossover frequency.[*]The +10dB is not part of the house-curve concept, correct?
Good answers! They weren't what I expected at first, but then I found the article I was thinking of. Of course, it turned out to be 15 years old, so may no longer be valid. It explains differences between subwoofer (bass management?) and LFE tracks.Agree^^ non of the room correction systems do the boost automatically however after running it simply turn up the trim level on the AVR by a couple db. 10db is huge and very few systems can handle it unless you have Sonnies :hsd:
Sincere thanks! That built my confidence.Good for you, for figuring that out. :T
Well said, and thank you! Helps launch me into creating house curves. I found the excellent guide you wrote. Here's an excerpt from the article I was thinking of when starting this thread.The process has always been to EQ as needed, then adjust the sub gain afterwards, as it typically needs to have the level re-set after equalization...
...I’ve never been a fan of rigid numbers like this, because the amount of gain in sub level needed (if any) is very room dependant, and also on user preference. That said, a boost in the 4-8 dB range is common, with the 25-30 Hz shelf in sub response being about that much hotter than what is measured at the crossover frequency.
I like that. Thanks for the chuckles!...that's the difference between reference bass and preference bass!
I'm not sure I understand you. Do you mean to say sub EQ instead? I didn't know a house curve could only be applied to a sub. Doesn't it only apply to full-spectrum audio signals. I suppose if your particular DRC software allowed you to manipulate different frequency bands independently, then my question would be: "What does rolling off the sub with a house curve do to the hard work you attained by smoothing the response in the XO region?"This is how i made a housecurve /boost on the low freq.
Ok, so this is where a lot of people get confused.Okay, I think I've finally answered my own question. If I'm wrong, please let me know. I'm not ashamed to be wrong--I'm married! :rant:
I found out that reference level is 105dB for main speakers and 115dB for the sub. That explains the 10dB difference I've been wondering about. So thinking of it that way, I believe the difference is encoded/mixed that way during production. Said another way, it's built-in to movie soundtracks (if the studio followed standards).
So the bottom line is that we don't need to run the sub 10dB hotter than the mains when setting reference levels in our HT systems. Am I right or wrong? And don't sugar-coat it! :boxer:
Yes to the sub only.I like that. Thanks for the chuckles!
There seems to be quite a bit of confusion (and therefore mis-information) in this thread about theatrical sound. The quote above is incorrect. At a reference level of -20dBFS the output of EACH of the front (3) speakers is individually calibrated to 85dBSPL(C) at the datum point, usually around 2/3 to the back of the auditorium, not to 75dB. Peak output for each of the fronts is therefore 105dBSPL, although obviously that figure can be significantly higher at the front of the auditorium.Reference level is 75db when running one speaker at a time when you combine all channels minus the sub it is 85db with peaks of 105db
Adding the sub those peaks go up to 115db but average is 85db with the sub average will be around 95db all channels
105db sustained is really loud and will cause hearing loss.
I would love to know what kind of signal that iswe use filtered pink noise files, specifically designed for LFE calibration
This is correct for surrounds, but absolutely false for LFE. ITU-R B.S.775, which is as close as it gets to a widely agreed standard for consumer multichannel audio, mandates +10 dB for LFE. My understanding is that virtually all AV receivers on the market apply the +10 dB LFE gain, as they should.consumer bass managed systems, which don't use -3dB in the surrounds or +10dB in the LFE
