1 - 3 of 3 Posts
· Banned
Hey guys,
I think there are more Alpine HUs that can run the PXA-H701, but here's the list I'm working off:
CDA-9887 good HU 4 volt outputs only $270 if I don't want to play DVDs...great buy
All the DVDs only have 2 volt rather than 4 volt. I know most think it doesnt matter..whatever. Price jumps double to go DVD with a screen
W200 looks fine, $500
W205 adds optical output, would I use this? $575
D105 the one I was really interested in cuz it plays DviX!! Can't find any on eBay!!
D106 $670
I don't see much option change to add all the cost to all of these. So I am deciding either 9887 if not DVD cuz its so much cheaper, W200 if the addition of optical out wont be used, but i believe I would benefit spending the extra $75 on the 205 to run optical to the H701? I can't find the DivX playing 105, and what's the point in the 106 for another $100?
Hey guys,
D106 $670
I had a 9887 in my Lexus. It was a good unit that offered TONS of tuning ability. I had mine running a 2 way active front stage. I think that a 2volt unit would do fine for what you're asking it to do. Your amp will be fine with it. Most higher voltage units dont get to that type of voltage till you crank it ALL the way up. And that's if it's an unclipped voltage too.
Do you have the PXA-H701 already?
· Banned
nope, getting everything all in 1 shot. looks like my batts, sub amps, wire, terminals, HU, and crossover may all be coming fro sicaudio and the woofers and home speakers from Kevin.
The votes are in, W200/H701 running the optical between them for audio and the Ai-Net between the two for processing. Then voltage wont matter anyway :)
What do ya think?
1 - 3 of 3 Posts
