1 - 11 of 11 Posts
yep, bigbadbill is correct.
That is my attempt at trying to calibrate my soundcard.
This is the old p3-700 with the soundblaster live value 16 bit card.
Brucek or anyone else have any additional thoughts?
Thanks all,
D
Hi D,
Run with your calibration. It looks like most sound card cal's.
If you look in the REW forum you will see many worse than yours.
Even if it isn't right you can do your graphs and save the mdat files and add the cal file later (I think, brucek will be able to confirm/deny)
Anyway start graphing and have fun.:yay2:
There's no need to ask if a soundcard calibration file is valid or not, since the validation should be in the form of a measurement of the loopback cable with the soundcard calibration file in place. The result of that measurement should be a perfectly flat line (if the soundcard calibration file is correct). This is because the cable has a perfect response, and the poor response of the soundcard is nullified by the calibration file you created.
Discussion Starter · #8 · (Edited)
alright Brucek or any other wise forum members,
I think I have something funky going on here. I had to crank up my levels on my initial soundcard calibration loop in order to get the levels to match (around -12.3db out to -12.3db right). My Levels on my wave volume and output volume are both at 1. My record (line in) is at 0.794 in order to do this. That gives me my first measurement line around 0 db.
Then, when I go to check if my soundcard calibration file is successful by leaving the loopback connection in place, unchecking the C weighted spl meter box in the mic/meter settings and press the measure button, I get the second line in green. Looking at the guide, it appears these two should both be around the same db measurement, or at least somewhat right?
Reading Bruceks response about the line being perfectly flat though seems to be accurate. It just seems like these should be closer together.
Again, the redline is the first calibration plot, and the green line is the "check if the calibration file was successful" plot.
What gives?:foottap:
Thanks and yes I'm a total newbster,
D
1 - 11 of 11 Posts
